Getting some ABS codes
Bigmd
Getting more CELs
For the last month I've been getting a few codes on my 02 4runner related to engine. I sorted those out with new O2 sensor and maf meter.Everything good for almost a month until this morning. All 3 lights came on again.A trip to advanced auto showed P0446 which i have had before but went away with new gas cap. It has occasionally come back, but usually after i get gas and all i have to do is tighten cap and it goes away. That didnt work today. Anyway i know it could be a variety of different things ,is there a way to narrow it down. Dont want to really spend 400 for vapor canister. Also what will happen if i just ignore it? I just passed inpection so not worried about that. I am also getting the c1223 and the c1246 mc pressure sensor. I've google searched but there isnt that much info on it. I did read the actual pressure sensor can't be replaced and the whole mc cylinder unit should be replaced. As we all know this is very pricey . I have also read that it could be just the actuator pump assembly which is a lot cheaper. Anyone have experience with these codes? I should add the ABS light is not on. I also have the original Andy mod on it. Not sure if that may affect it. Any help is appreciated.
Same here, and I see you haven't got a reply to your problem :confused: Mine first start with A/F sensor, I didn't change it because it would go and come (lights would be on and then off) now I have a list of them and seems finally the lights are staying on.
P1135 is the original problem- 1 month ago
added as of yesterday
c1201
c1223
c1224
c1241
c1246
c1252
c1256
Even though some are ABS and Brake related no brake light or ABS illuminate or flicker other then the normal test on at start up
Wow almost 3yrs old lol. Anyway i wound replacing the vapor canister with a good used one and made sure to seal it with jb weld at seams. I also replaced the vsv sensors in engine compartment and at that canister itself. The master cylinder code went away eventually but not before I bought a used mc on eBay. I still have it just in case. Knock on wood I’m cel free for a few years now.
Thank u so much for the update
Did you have an issue shifting the car out of park when this happened?
AndiGarage
