glove box
need info
i and a lot of other people could tell you how to take it out if we know what model and year you have! my 88 4runner is definitly not the same as a '95 or a 200+ model
reply back and give everyone some info please
still have yet to find the answer, can someone who is reading this point me in the right direction to removing glove box...
is there a way i could get a 10x10" project in there - if i cut it or something? does the case itself dissasemble? i can make a case inside there if thats the situation
The glovebox is super easy to remove. Just open it. When it is all the way open, there are rubber grommets at the end that keep it from opening too far. You just need to squeeze this area together and this will allow the rubber grommets to pass, and the glovebox will be completely open. Then, I believe (it's been a while, so I am a little foggy on this step) there are a few phillips screws to remove at the very bottom of the glove box, and it will come completely off. Then a few more screws to remove the small black hidden box at the top part of the glovebox space....
Good luck
D'Angelo
