Going after a ball joint
DEF4Runner
Going after a ball joint today, but can't get this piece of the steering knuckle off off.
Recommendations?
I used something like this. Mainly because I had one. I think there is a tool that works a little better that you can rent at Autozone.
TB1hXiYIpXXXXcBXpXXXXXXXXXX_0-item_pic.jpg_210x210_zpsfye9uxzq.jpg~original
Interested to see how this turns out, if you have trouble getting the knuckle disconnected...good luck with the joint
I did both of mine last week. I sprayed them down with PB Blaster and turned that 90 degrees so that steering stop was pointing outward. I supported the lower arm with the floor-jack and a couple of swings with a sledge hammer to the steering stop and that steering knuckle attachment came right off. The big ball joint kit from advanced auto / car quest made easy work of the ball joint.
