GPS suction cup keeps falling off
snhrph
My Magellan Roadmate 2200 keeps falling off since the temperatures went down - suction cup just does not hold.
Any ideas? I would appreciate all advice.
Thank you.
Make sure the mounting area is clean -- I find that it doesn't take much haze/dirt for the suction cup to lose its grip. Next thing I'd try is a little moisture in the suction cup before you mount it.
x2...i use a small amount of my saliva around the inner edge of the suction cup.
This is a common problem, mine does it in the cold weather too. I have found that, as others have said, that keeping the surface of the windshield clean helps. I use a razor scraper to clean off the 'circle' left when you remove the suction mount. This also helps to not advertise you have a GPS in the vehicle when you store it away when parked. Also, when it gets cold, I try to warm the rubber material of the suction cup up a bit before applying it to the windshield, it is more pliable, and will work better when warmer.
Interesting. I've never had a problem sticking it to the windshield. Its the silver part on the dash that it doesn't want to stick. I'll try the saliva thing!
I use body lotion and rubbed some all over the suction cup. Temperatures here in CO went -30 for a couple days, 'til now my Garmin hasn't fallen yet.
I was actually thinking if using vaseline (petroleum jelly), but was not sure I wanted to clean up the mess if it did not work out.
I'll try that tonight.
I read somewhere quite a while that oil-based substances like lotion, vasoline, or stuff like that can make the suction cup adhere extremely well to surfaces. It was something to do with that water and saliva dry out very quick, but these oils never dry. Never needed to test it out, the cold doesn't affect Florida too much. :P
Man, i learn new things everyday on this forum...i will try vasoline next.
Re-installed today using Vaseline. The cup slides a little on the mounting disc, perhaps put a bit too much. Will see how it holds.
I'm surprised some of you have Vaseline (is it KY gel or something in that nature) laying around your house. LOL
Well, once you grow up, you realize that Vaseline, is not only associated with self-gratification :wow:, but with chapped lips, small rashes, scrapes and abrasions that kids can get... :wink2:
Must be new technology. I'm from old skewl. I use chapstick for chapped lips. I use johnson's baby powder for rashes. And for scrapes and abrasions; wash with soap and water, pour isopropyl alcohol, and a bandaid. So i'm sorry i know nothing about vaseline other than whether it's the gel or a product lotion.
Update
Vaseline worked very well as the GPS mount held up in its place for 9 months. It probably could have held longer, but I knocked it off yesterday.
Thank you.
This NEW and Amazing product will fix this for you. I had this problem also and was worried that the unit would break from one of the falls, well not any more and no more salavia on the suction cup either.
Gives the suction cup on your GPS, radar detector, or other electronic device a "gator-like" grip
Easy to remove
100% natural, biodegradable, non-toxic, and Earth-friendly Water soluable and non-staining
Made in the USA
follow the link or cut and paste it into the browser
Amazon.com: MawMaws Suck-It-Up Suction Cup Securing Liquid, 2 oz. Bottle: GPS & Navigation
