Grinding the Tundra caliper to fit stock 16" wheels...
DK327
Member
Hey all, this has been beaten to death on here but here is yet another question about a Tundra break upgrade... I have 00 T4R LTD with stock 16" wheels so I already know it won't clear... I don't want to get spacers and I don't want to get new wheels, so my question is, instead of grinding part of the wheel, would it be possible to grind just the caliper? I know the dust shield also needs to be cut, this is not a big deal, I just want to know if I could get away with just grinding down the surface of the caliper itself without touching the wheel... Thanks!
Which wheels you have, I think some fit.
I believe both of these wheels fit and both are 16". I know the first ones are Tacoma wheels but they are still 16"
If he has the split tri stars than they wont work, I think 2000's came with the older ones.
To the OP I heard you can grind the caliper but have also heard people say the fluid passage is near where you grind and you can go to far rupturing this fluid passage.
I would grind the wheels or get spacers.
Take the calipers back and get the 199mm if you have the split 3 wheel.
199's will fit the split three spoke.
231's fit almost every stock wheel except the split 3. And anything 15".
But for sure, don't grind anything.
Please check a couple of posts above, I posted a pic of the rims... I don't think mine are split tri star... Is the one below the split tri star? Sorry I don't know the terminology... Being a noob and all...
I wouldnt grind anything, just pick up some cheap, but quality 1/4" spacers ( IF you need them) But im pretty sure they clear the wheels pictured. I payed $10 for spacers and picked up some ET lug nuts which added 1/4" more thread engagement, so it still bites onto the lugs the same amount.
Trimming the dust shields is 100% required.
Yes, these are the split 3 spoke. They willl rub the wheel, you have to have about 1/8" spacer to clear, hence why i got 1/4".
Thanks all, I think I found the answer to my original question... I re-read the BigFishAllDay's post regarding this upgrade and it turns out i have the "OEM 4-Runner "5-Star" wheels" that's on his white list of wheels that would fit the 199 and 231 calipers. Info is on the 7th post on the below thread:
http://www.toyota-4runner.org/3rd-g...ents-231mm-13wl-tundra-calipers-rotors-8.html
Yours will only fit the 199mm, not the 231. IDK, if you were going that direction or not.
Can you confirm that factory 5 stars will NOT fit the 231mm? According to BigFishAllday's thread outlined on above link they should... On the next page he did this on a family member's T4R that has the 5 stars and they fit OK?
http://www.toyota-4runner.org/3rd-g...ents-231mm-13wl-tundra-calipers-rotors-9.html
And here, towards the bottom, a couple of more people confirm they fit without any grinding with 1/4" of space between caliper and wheel...
http://www.toyota-4runner.org/3rd-g...nts-231mm-13wl-tundra-calipers-rotors-14.html
DK327: your 5 star wheels will definitely fit with the 231 calipers. I have the same setup and there's no rubbing whatsoever.
[MENTION=125731]GaRunner86[/MENTION]
Can you tell me which longer lug nuts you got for this? Got a link maybe?
Agreed. I did this yesterday. I have an 2002 with OEM 5 stars and a 231MM Tundra upgrade with Power Stop and Brembo rotors. It works great.
On another note....
DON'T GRIND YOUR EFFING CALIPERS. EVER. I KEEP SAYING IT AND I DON'T CARE IF IT GETS ME BANNED. AS LONG AS I MAKE MY POINT. NO CALIPER GRINDING. EVER. PERIOD.
Sorry I thought you posted that you had the split 3. 5 stars will fit the 231's for sure.
Guess I should stop half reading :)
Hey, even I was starting to get confused towards the end... I'm fairly certain by now that they will fit so I'm getting this "kit" and will call it a day.. I wish it were the semi metallic or whatever but I'll live with ceramic...
I love that they are Callahan, LOL!!
I like that setup. Can you post a link?
I just went to the shop I bought the wheel/tire combo from and told them I needed "ET " style lug nuts. They fixed me up. The type of ET you need depends on the type lug nut u have now, ex. Acorn, conical, etc.. They cost be about $1.50 ea.
Laredotx
