Grinding the Tundra caliper to fit stock 16" wheels...
Please check a couple of posts above, I posted a pic of the rims... I don't think mine are split tri star... Is the one below the split tri star? Sorry I don't know the terminology... Being a noob and all...
That's my 4runner!! When it was stock!!
Hebrew.....what 199 kit did you buy?
I got calipers, rotors, pads from a wrecked 01' Tundra. I heard the '01 was compatible with it's 199mm's and no grinding necessary. I think they changed the design in 2002 for the tundra, so I can't vouch for compatibility from any other year.
The 2001 199mm calipers are straight bolt on, no mods. I have the 16" wheels.
<a href="http://s1064.photobucket.com/user/andyfirecharger/media/d4d0396b-0a34-41bc-8cc9-ae6f3b2ab88d_zpstfyhghx8.jpg.html" target="_blank"><img src="http://i1064.photobucket.com/albums/u369/andyfirecharger/d4d0396b-0a34-41bc-8cc9-ae6f3b2ab88d_zpstfyhghx8.jpg" border="0" alt=" photo d4d0396b-0a34-41bc-8cc9-ae6f3b2ab88d_zpstfyhghx8.jpg"/></a>
5-spoke (star) will absolutely fit. I have a 2000 limited as well and put in the 231s without issue. You'll need to grind down the dust shield.
I just went to the shop I bought the wheel/tire combo from and told them I needed "ET " style lug nuts. They fixed me up. The type of ET you need depends on the type lug nut u have now, ex. Acorn, conical, etc.. They cost be about $1.50 ea.
Longer lug nuts work to grab more threads, with the same length threads?
I still think the front studs are too short, without any spacer.
These lugs i have "reach thru" the spacer ( or more like a shim since it is so thin) so they engage the same amount of threads.
I DONT like these type spacers, but i have to live with it right now, no issues in over 30k miles.
I'll probably just upgrade to a wheel that clears the 231's when i get ready for new tires.
Laredotx
