Group BUY on Outdoorlogic 3rd Gen Front Bumper
Xrc8 smittybilt winch installed today at Jimmy's Shop. I had a great time hangin out with Jimmy. What a great guy.
So I don't feel like reading through this thread to see if its been mentioned but does anyone know whose runner this is w/ the ODL prototype rear swing bumper?
P5100151.jpg~original
P5100150.jpg~original
That thing is sick, I want to know how much it cost!
Ok, got the bumper off anyone had an install write up. Looks like I grind off the bumper mount on the frame and drill holes on the frame. Then use 2 side origianal bolts.
Lights- can I just splice into the turn signal and fog lights harness already on the 4runner?
Thanks for any info!
I can't wait to pick mine up (hopefully) by the end of the week. Great looking bumper and Jim is a good guy to deal with.
Can't wait to get mine! Got my old xrc8 ready to go! Any install tips tricks?
Teaser pics. Full build thread to follow with bumper done. Lots of work. Bought as a wreck. 2000 limited
SL384158.jpg~original
SL384152.jpg~original
It's pretty straight forward. I was confuesd at first too. Just get something that will make the bumper the height that it would be then when you get it up to the vehicle you'll know exactly what to do.
To get ready you can go ahead and cut the stock plate at the end of the frame. Don't cut the plate off but cut the plate the size of the end of the frame as the bumper slides over the frame. I slid the bumper on to where the stock bumper side mounts matched up to the mounts on the ODL bumper mounts. Then bolted the side mounts with the stock hardware. Then took a long 1/2" bit and drilled the frame holes with the bumper on that seemed easier than marking and taking back off. Especially since it was a tight fit jockying the bumper on. A 10-12" bit works good, the 4" bit made the drill bind and not reach all the way through the other side of the frame.
To make things easy I would wire the fog lights before installing. I used the wire harness from factory fog lights so that way it is just a plug in and can unplug to remove bumper to install winch later. The blinker lights have a plug in to the back of the light so easy to wire after the bumper install.
Here are a few pix
http://www.toyota-4runner.org/3rd-gen-t4rs/95292-outdoor-logic-bumper-install.html
Really?? how much did that end up coming out to?
I've wanted one for so long!! And was waiting for a sale again like the first one they had.
Install
so im going to be placing an order for mine soon, and i wish i could install it myself, but i simply dont have the tools or expertise..... So if i take it to my local off road specialist should i give them any specific instructions for installing this amazing piece of metal?
If you're mechanically inclined at all it's not hard. I used a SawsAll and belt sander to trim the end plate (top and outer edge) I trimmed the bottom just to even things out, and you have to trim a small portion of the plastic fender well and a metal bracket from the terminus end of the fender.
025.jpg~original
A little Rustolium gloss black and your ready for a test fit. There's more to it than that, it took me the better part of the day to drill out the frame and get it to fit right, bolted up and turn signals wired-up. The end result is satisfaction in doing the job yourself. I'm a little embarrassed in posting this pic all over the place, but I'm really happy on how it turned out.
gaurd1038.jpg~original
