Growl in front end
CDM4RSD
Good afternoon. I recently bought a 2006 4Runner V8 Limited and have noticed a growl with occasional vibration coming from the front end. I've installed both front hubs (from nj636 on this forum) and the growl is still noticeable.
FYI...I've already tested both rear wheels for play (12 & 6 and 9 & 3 push/pull method) and do not think it is a rear hub problem.
Does any one have an idea of what may need to be looked at next?
Thank you in advance!
Stock size Michelin ATX MS2. Brand new, installed at the dealership and had an alignment done too. No lift or other mods.
No idea, if new tires and hub are new that's all I can think. Maybe a dust shields os rubbing on caliper?
It's could possibly be a rear even though you have checked.
Thanks. I'm also in Knoxville. I'm sure we will pass each other around here sometime.
Figured it out thanks to te guys at ProToy in Knoxville, TN. Driver rear bearing was bad. Going to have both rears done tomorrow.
