Guide: Radiator and Thermostat Replacement for Noobs
hour
I wrote this up because I was taking pictures along the way and most of the referenced links are more text than picture. It really wasn't that bad following the text directions but hey, what's the harm in having another write up?
I replaced my radiator because after doing a flush it was running hotter than ever, and I was certain that there was no more trapped air in the radiator. I / others on here suggested thermostat was bad or radiator was clogged... In any event, had I done all of this from the start I would have saved a lot of time.
Parts used:
ToughOne/Ready-Rad radiator from AAP (#431402) - $114
ToughOne 13psi Radiator Cap (#10241) - $8
OEM Thermostat (#90916-03075) - $21
OEM Thermostat Gasket (#16325-62010) - $7
3 gal Zerex Asian Formula Coolant (#675130) - $14/gal
Total: $192
Edit: Including some alternate radiator part #'s and comments
I can't comment on these entirely since I only used the radiator specified and haven't tried any others.
OEM radiator: #16400‑75180 - have to assume it'd fit like a glove
Koyo/TYC 1998 - I don't know how to comment, research indicates people say these are interchangeable (as in you order Koyo, get TYC) and some people claim it fits exceptionally or not well at all, such as post #4 in this thread. SEE BRIAN'S COMMENT ON KOYO/TYC IN THIS POST
Spectra (Autozone): #C1998 - didn't have any reviews on Autozone.com so I kept looking
End edit
You can also replace the upper and lower radiator hoses (and clamps) if you want. I didn't, but probably should have. Really wanted to get this wrapped up over the weekend, so maybe order those in advance if you can. I'd stick with OEM hoses to eliminate any possible variables. Camelback Toyota has the hoses and thermostat + gasket for way cheaper than my local dealership, wish I had planned a little better.
Tools used:
12mm socket (12pt), 12mm deep socket (6pt)
10mm socket
Socket extensions - one roughly 1.5", one about 3"... can improvise
Needle nose pliers
Bucket and drain pan, funnel
First thing to do is remove your front skid plate. I figure mine may not have all the bolts, or they're in different locations, but it's a few 12mm that you'll need to remove.
1_skidplate_zpsb02105ed.jpg~original
With the skid plate off you'll have good access to the petcock at the bottom of the radiator. Loosen/remove the fill cap, position bucket, and start the draining process. It'll flow from the circled hole, don't remove it entirely or you'll spill.
2_petcock_zps599ea23f.jpg~original
Draining can take a while so you may as well work on the stupid grill at this point. This is the second time removing mine and I'm pretty sure all my clips are toast. In my opinion, this was the most difficult part of the task - and I had already done it once before.
3_removegrill_zpsbab8b431.jpg~original
After the draining is complete, pull the lower radiator hose and expect a little more coolant to come out at this point.
4_lowerradiatorhose_zps57e66efa.jpg~original
You can go ahead and remove the upper radiator hose too at this point to get that out of the way.
99_upperhose_zpsd645ad2a.jpg~original
Disconnect your transmission cooler lines at this point, I photographed where they connected to the hard lines, but you'll be looking for the two on the bottom of the radiator. Yank one at a time and catch the little bit of transmission fluid in a proper drain pan. If you have an external cooler you may as well remove your zip ties from old radiator (or do nothing if you installed with brackets)
5_disconnecttranscooler_zpsf0f80564.jpg~original
Remove battery bracket while the transmission cooler lines are dribbling. This will allow you to yank the overflow tank out and clean it.
6_removebatterybracket_zps41f3aaba.jpg~original
You'll also want to disconnect the line to the overflow tank from the upper radiator neck. This will be the last tube running to the radiator, so have a beer if you weren't already... the messy part is nearing an end.
7_disconnectoverflowtank_zpse35b7f72.jpg~original
Lift the overflow tank straight up, it slides in on a track. I photographed this because mine was being a PITA to yank up, and I questioned whether that was the correct procedure. I didn't want to manhandle it and end up cracking the tank, so yeah... here's how it attaches.
8_removeoverflowtank_zps984cbc0b.jpg~original
You'll then want to remove the 4 10mm bolts that hold on the fan shroud. The passenger side bottom one was difficult to access because of the transmission cooler lines, but once I got it loosened with socket wrench I just undid it with my fingers. Two of em are down low, maybe use a flash light. Move it towards the windshield after you free it, to allow some wiggle room for the radiator.
9_removefanshroud_zpsf4d3805e.jpg~original
Use a 12mm socket to remove the four bolts now holding the radiator in. You'll be able to remove it next.
10_unboltradiator_zpsaf0ce814.jpg~original
This bolt is in a terrible location, but having the grill off and attacking it from the underside made it doable.
11_unboltradiator2_zps085adfb7.jpg~original
With the fan shroud off and moved back, all lines disconnected, and the 4 bolts out that hold the radiator on, yank it straight up like you did the overflow tank. It shouldn't weigh too much now that it's empty, and you get a good deal of satisfaction throwing it in to your yard. Once the radiator is out you can then remove the fan shroud entirely to free up some room for thermostat removal.
12_removeradiator_zps9d369003.jpg~original
Now for the thermostat, if you're doing it. I stress using the 6 point socket on these nuts because one of mine started to round. Maybe hit them with PB blaster the night before. You may need a deep 12mm socket, as you're just removing a nut and the bolt/pin itself might be too long for a regular socket. I also disconnected the top of the hose that connects to the thermostat housing just to get everything out of the way. You'll do that anyway if you're replacing the hoses.
13_removetstathousing_zpsc7f063e5.jpg~original
Here's the thermostat, grab it by whatever you can and give it a wiggle to unseal. You'll get another coolant splash doing this, so be prepared with your bucket or get your face out of the way.
14_yankthermostat_zpsbc8f3f88.jpg~original
Prepare your new thermostat by putting your new gasket on. Orient it so the circled jiggle valve is facing the ground. Pop it in. It might not stay too well inside the hole at this point, so orient it and try not to bump it as it will easily fall out.
15_reinsertthermostat_zps928ebd0b.jpg~original
Have another beer because the next several steps are reassembly. Put the thermostat housing back over the three bolts, gentle to not bump the thermostat. Screw on the three 12mm nuts you took off, and using a socket, get them all finger tight equally. I may have not done this the first attempt as I had a leak, so... do this. Once they're all finger tight you can torque them to 14 ft lbs. Don't overdo it.
I installed the new radiator at this point, very easy. Just slid it down the reverse of how I removed the old one, and waited for the 4 bolt holes to line up. The fit was perfect with the mentioned radiator, and I simply put in my old 4 bolts.
Reconnect the bottom hose to the thermostat housing and the radiator, the transmission cooler lines (if using radiator's cooler), and move clamps in to position. I've read that people prefer to use new transmission cooler clamps when reattaching, I didn't since I have an external cooler. Connect the top hose and clamps, and then move the fan shroud in to position and put bolts in. Reconnect the overflow tank hose to the radiator fill neck.
Alright, almost done. Your thermostat is in and all hoses are reconnected to the radiator. Make sure your new radiator's drain valve is closed tightly, and start your filling process. After adding a little over a gallon, peek under the truck and make sure nothing is dribbling. It took right around a gallon for my thermostat housing to start dripping the first time around, hopefully you won't have this issue.
You should be able to get right around 2 gallons in before the radiator acts like it doesn't want to take anymore. Flip the temp control to full heat and fan to full blast. Also turn on the rear heater to full hot / high fan. Turn on the car.
You may see a little coolant accepted through the radiator shortly after turning on, maybe coincidence, but the level in the radiator will drop a good bit after the thermostat opens. This happened for me at about 181* displayed on my Torque app on phone. Add more coolant through the funnel and periodically give the upper radiator hose a squeeze. After about 15 minutes of total idle time I was pretty convinced that it had taken all it could. I capped the radiator, turned off the car, and filled the overflow tank to the F mark (it was still empty).
Take for a test drive with the heater control to COLD, ac blasting if you're like me (torture testing). My temperatures had consistently been 212*F after dogging it and hitting a stop, now I'm at 190*. If your temps are high, try pulling up on a curb or getting the nose high and adding more coolant. Be sure to let things cool down a bit before popping open the cap if you pull over to do this. I plan on carrying some extra coolant and a funnel around for the next several days just to be sure, but all seems A-OK.
16_enjoytemps_zpsa00aab7f.jpg~original
Again, this is really detailed for a seemingly simple task, but I managed to bork it yesterday by not installing a new thermostat, and again by having the thermostat leaking a bit. I've read of ridiculous dealership prices for this work, it's really not that bad!
Glad your radiator seemed to drop in with no issue. I got the TYC 1998 from Amazon and of the 4 bolt holes on the brackets, only one would line up enough to thread a bolt in at any given time. I tried swapping the brackets from my old radiator, but the mounts on the radiator were spaced further out, so the factory brackets were too wide. I ended up jamming two bolts on, filed a third hole out enough to put the bolt in and left it at that. Something that should have taken 5 minutes took me two hours of swearing, swapping stuff around, and head scratching.
The radiator works just fine, but those damn brackets made me want to fly to China and punch the guy that made the brackets in the face. How do you get something that wrong and (more importantly) how does that junk get past QC?
Lol on the last paragraph!
Cool write up although can you include the OEM part number for the radiator? Or least also mention the Koyo.
If that cheap aftermarket radiator fails you could be at risk of a pink milkshake. OEM rads are well proven to last 15 years. Aftermarket is like Russian roulette.
Correct, it's Torque Pro. We have a bunch of old android phones at work so I just donated one of my development phones and took a ghetto one (er I guess it was top of the line 3 years ago).
For anyone interested in that, you can buy a 'burner' phone from Best Buy or a million other places for cheap. I have a $65 LG Optimus Exceed II that I bought last week for work, and it also works with Torque exceptionally well. No contract, didn't activate (skipped activation once using a trick I found on youtube, never prompted again), money!
Brian, I don't know the part numbers of anything else. I just posted what I used. A mod can edit my post if it makes it in to any list of guides, or if others want to post up their experiences (direct fit only, lets skip the questionable mounting TYC1998) I'll edit first post. Pink milkshake is null issue for me with an external cooler, but ReadyRad has enough reviews for me to personally trust. Starting off with a new radiator and new fluid should curb corrosion for a very long time and make the pink milkshake a null issue, unless it was constructed improperly (in which case I'd assume you'd have fluids mixing from the get go)
Are you able to replace the thermostat without draining the radiator? Just wondering because I need to replace my thermostat after installing a SC and would rather not refill the entire system.
I'll find the part number and post it.
I think you should be master of you own post so if you want to include it thats cool.
It's nice to see a write up like this with some pictures.
Cool write up, thanks for all the pics. Btw, what did you used to edit/comment on/ draw on your pics?
I saved a layer group in Photoshop with the tinted section and two text fields, then moved it to each picture I was saving and recaptioned. Yeah, it kind of sucked - not the easiest way.
I've read about people replacing thermostats with the lower radiator hose attached (to radiator and thermostat housing) but you'll have much less room to work with. Also, my thermostat (even with everything drained) still shot out coolant once I yanked it. I'd imagine with it undrained you'll get an even more significant splash, though it may not be that much of your total coolant volume.
I added OEM, Koyo/TYC, and an Autozone part number. OEM is clearly a solid choice but I don't want to give people any reassurance with TYC, since people get TYC or Koyo when ordering one or the other, and some (including post #4 of this thread) had bad fitment. Also included Autozone radiator part number, people seem okay with the 'Spectra' brand radiators in general, but without any specific reviews for 4runners - beats me. I encourage anyone trying a radiator other than the one I used to do some additional searching on the board to ensure fitment and quality.
I feel you Bandman...I had the same problem. Two of my bolt holes lined up, but the other two weren't even close! I hate crap made in China!!!
OP...hats off to you!! One of the nicest and easiest DIY write ups I've seen!! Please don't stop at this one...please continue.
as in you order Koyo, (but) get TYC
Koyo part # ___
TYC part # PA66-GS30
Koyo is a solid parts mfgr out of Japan. They produce the radiator for Toyota for multiple years, at least that's what everyone here says that's looked into it.
TYC is a cheap replacement parts company born and made out of China. TYC has been accused multiple times it misrepresenting themselves as Koyo on eBay and other non-direct sellers.
A few years ago they were just repackaging the real Koyo radiators but I suspect that by now they might have started reproducing their own cheap version. Most of the posts about reboxing are from 2012. I have seen a few newer posts that indicate TYC is actually making "their own" version now (or at least their own box lol) which if trues means you will not get a real Koyo despite the 2012 policy.
A real Koyo that was just relabeled used to come in the Koyo box and say Koyo on the rad. If it's a cheap remake it will not say Koyo.
Check this out for clarity ---> http://www.toyota-4runner.org/3rd-gen-t4rs/114586-radiators-koyo-vs-rest.html
From March 2013:
I decided to call KOYO and found out that TYC is one of their largest customers and KOYO does make this particular radiator for them, TYC simply "re-brands" them by putting their name and part number on the side of the box.
I think this thread is pretty useful, especially with all the pics. I will find a spot for it in the tutorial thread.
:bat:
I wrote this up because....
Parts used:
This is great man. I am planning to get this done on my truck this weekend, your guide would be very very helpful!
I am just planning to get the radiator changed and leave everything for later. Hows the AAP radiator holding, I am planning to get it for my truck as well? I ordered a Denso from Amazon but it was damaged in shipment and I dont want to risk that again.
tabs
hour, you're the something awesome today.
Hmm,
you put your jiggler valve a 6 o'clock. I've seen a lot of writeups to put it at 12 o'clock. The online FSM says 6 o'clock, but it is from 1998, so this might have changed since then. 12 o'clock would make more sense to me, since it allows air to escape.
So which one is it? Will it really matter?
Yes, happy with the AAP radiator. Obviously too early to tell much, but I have no regrets. If I had planned further in advance I probably would have sought out an official Koyo. Needed the radiator the next morning, ordered it online from AAP and got a 15% discount + $25 off my next purchase over $50, so I was pleased. IMO, the more important part about the durability would be the transmission cooler, but I can't/won't be able to comment on that since I run a separate cooler only. My thought process is that if they're constructed acceptably in the first place, and I'm running new proper coolant with every intention of keeping up on drain and fills / flushes, corrosion won't be much of a concern and the pink milkshake unlikely.
You're the something awesome today.
Push down on tab from side with flat blade screwdriver. View attachment 122568
I see attachment text when I quoted you but no pics. I definitely pushed the tab, but the tab was visible from the top. A little yank while pushing in tab made some come out rather easily, but others were not as compliant. Also seems like in the two times I've had the grill off that I end up pushing other tabs back IN while trying to remove the remaining few.
Hmm,
I researched this whole process pretty thoroughly and was convinced that 6'oclock was the way to go. In fact, a lot of threads pertaining to people running hot are answered by members here that I certainly trust, instructing the person to check and rotate to 6 if needed. This seems to have solved other people's issues. In any event, I run at about 190 consistently and didn't break 200 offroading in Moab so I'm pleased. It will matter if you end up having to yank it out right after you do all of this because you're running hotter than you'd like. If I were you, I'd do 6 - or search around the board if you'd like to find the discussions that sold me on orienting it that way.
Mike Sargent
