Guide: V8 Timing belt replacement 2UZ-FE VVT-i
Part 4: (I think??)
One thing i found helpful here - is there was no need to loosen the top rear AC compressor bolt, it has nothing to do with the fan pulley bracket. i just removed the front 2, and bottom (behind the oil filter) bolts - and the bracket came right off.
Also, for the crank bolt - i don't know if i got lucky - or just set myself up properly. But Using a crank holding tool (this one) 2 each of the 24" breaker bars from autozone loan-a-tool, and 1 22mm impact socket made the crank bolt surprisingly easy. I installed the holder tool with the 1/2" insert facing downwards towards the driver side frame, 1 breaker bar connected to that, resting against the frame, and the other breaker bar at high noon to pull on the bolt and it came right off with 1 person, no bs, no starter hack.
My new-to-me 2005 v8 is at 177kmi. The timing belt inspection sticker says it was changed at 101kmi.
At present the belt looks in perfect condition to me. I also had a pre-purchase inspection done on it.
Should I replace it at 190kmi, or wait till 200kmi?
And when I do get it replaced, I probably will just pay a shop to have it done. How much can I expect to pay for a timing belt replacement?
Update. I took my truck to the local Toyota shop to have them put the engine in proper time. It runs perfect now. No codes and my hp is back. 3.5 hours plus another belt since he said the timing belt would have stretched and would need to be replaced even though it would have only 40 miles at best on it. I call bs on the stretching scenario but at least the new belt would be OEM. I shelled out another $500 for this job. A painful lesson learned for sure.
Interestingly, the Toyota mechanic stated that this engine is NOT an interference engine and that there was no need to worry about the belt breaking to begin with. ??? I told the “service advisor” who relayed that info to me that the mechanic is mistaken and that this is indeed an interference engine. He looked it up on his Toyota info and even called me later to inform me that the mechanic is correct, that my engine 2005 2uz-fe VVTi 4.7V8 is NOT an interference engine. Any thoughts on that tidbit? What a stressful nightmare this has been!
All engines are interference engines for the most part if you really want to get technical about it...
That being said, the 2UZ-FE is considered an interference engine because of the valve overlap/piston clearance IF the engine where to come out of time at a relatively moderate RPM. I have been surprised by many of the VVTi units I've seen snap a belt and survive (maybe a dented valve or two; but nothing warranting replacement/further tear-down beyond a new belt). But that's more being lucky than anything else in my experience.
Post Note-
Seems like it's time to retire my T-Belt DIY thread now. :)
Post Note-
^thank you for the high praise BlackWorksInc. I take tons of pictures every time I do work on my cars and I think the OCD in me helps. Just figured that since I had just completed the job I might as well post my work.
In my opinion, 10km difference is not an issue... 40 - 60 and we might have a different situation. That being said, modern day timing belts are pretty darn robust. I think of a timing belt job as more of an opportunity to replace all of the pulleys, tensioner, and pumps as well as the belt on a new-to-me vehicle. I like to know that wear and tear systems are in good standing order on my vehicles. Probably a bit over the top, but there it is.
As far as cost, I was quoted $2,800 for the job replacing all of the components that I did myself. I've heard it can be as high as $3,500, and I am sure u can get it for a little less than what my shop quoted me. So, I saved SOME money, got myself some tools, and had a great time doing it. Next time I do the job it will cost me significantly less and be a considerably shorter project.
Wanted to say thanks for this guide. I had the FSM printed out, had videos queued up if necessary, but really only refered to the images in this DIY. It that good.
A few notes from my own install that might help someone:
- Put painters tape on vac lines and connectors so you don't forget
- There's plenty of room with the radiator still installed but just put a pizza box or some other cardboard as protection. Even before fan removal.
- 2 12mm for fan, 12mm+long screwdriver for final one. May need to pry the fan off. Take off aux belt before doing this.
- Drain both block spigots with 10mm swivel socket (not just u joint) and like 2 ft of extensions. Then it won't splooge everywhere when you take the parts off the front of the engine.
- 14mm swivel socket makes rear bolt for AC compressor very easy
- Need very large breaker to jam under drivers frame rail when loosening crank bolt. I used 3/4 drive 36" breaker to crack it loose. Also had to Dremel flutes into the M8 bolts to basically make a bottoming tap because my balancer had 18 years of Northeast shit in the holes. Have a puller on hand just as insurance policy. I surprisingly didn't need it.
- Verify timing on the lines and 0* mark first, and the little casting nipple. Then use the T markings for the actual belt swap.
- Cleaning the WP gasket material thoroughly off the block is the worst part of the job. Have razor and Scotch Brite and determination.
- I had to work my new TB tensioner in and out in my vise before it applied uniform spring rate. At first the top 3/16" travel was quite weak. Same thing with the NTN unit in the Aisin kit and the NTN from the dealer.
- Install belt from crank, to Lcam, to WP, to Rcam, to tensioner. Get all slack to tensioner side before pulling pin.
- Between old belt stretch/new belt and fresh tensioner etc, I think there is a visual couple millimeter "margin" where, as long as the marks aren't like obviously off, don't sweat it.
- Reattaching the AC compressor to fan bracket takes jimmying.
- Have torque specs on hand for reassembly.
- May need to re-learn idle afterward.
I am going to be doing this job again at some point in 2026. I will try to update the guide with some of these tips, as a couple of them caused me to smack my head and say "duah" out loud when I read them. Thanks for sharing your experiences.
I am wanting to do this job myself too, but just for starters I have seen some people just do the first part of this guide to get access to see the belt in order to check its condition, it looks quite easy for a good peace of mind for anyone that just bough their 4runner without any service records
Philthyphilthy
