I have a Browning, in that price range thats very nice, also check Dicks Sporting Goods web site, they carry the Field and Stream line of safes at a more reasonable price range. Also it depends on how many rifles you want to store. If it says it holds 24 rifles, take at leat 6 off that, any safe will hold what they say if they are small rifles with no scopes, and crammed in there.
I read earlier on here about quick access to your safe. If you concern is to get a firearm out for protection then a separate pistol safe may be better than a large gun vault. Most people don't have time in that situation to get up go to the room the safe is in an them open the safe. The newer fingerprint pistol safes seems to be fairly reliable and should do an adequate jobs of securing your home defense weapon of choice when your not home.
A few years back i bought a BigHorn gun safe from Costco. Can't beat the price and curbside delivery. i'm very pleased with it. Weighs about 600 lbs so hopefully you have some good equipment to get it into position.
A tip for moving gun safes really easy if you’re on a tile or wood floor without breaking a tile or scratching the wood, cut a 10” tall strip of cardboard long enough to wrap completely around the safe and tape it together at the base. It should be able to slide up and down around the safe. Go down to the local driving range, buy a basket of golf balls, tip the safe back and put as many golf balls as you can under the safe and let the cardboard slide down to the floor holding the golf balls under it. You can wheel it around with one hand after that, move it in any direction, even spin it in place and the golf balls dissipate the weight beautiful. After your done moving the safe take the golf balls back to the driving range and have fun smacking some balls. Got this from a friend that delivered safes as part of his job and worked great for me when I had to move my safe into a space that would have been extremely difficult to get it into and it made it really easy.
