hard shift on downshift ...HELP!!!
tenro1
I was on my way to work this morning, in usual stop and go traffic in Atlanta...doing 5-10 mph. All of a sudden, I experienced a very hard downshift from either 3rd to 2nd or 2nd to 1st...not sure which...strong enough to feel like I hit a pothole. Truck is a 2001 t4r 2wd automatic v6.
I experienced 2 more of these during the course of the drive....both on downshift, both after moving off accelerator to brake...
What is causing this? I checked my vitals after parking at work - trans temp was at 173....coolant at 203. Checked the trans fluid - it looked good. Checked the coolant in the reservoir, it looked good as well.
One thing I did notice is that when the truck is in drive - the green light behind the D seems to be dimmed...not bright like before...and not bright like any of the other trans positions on the shifter...is this an indication of a problem?
Need some insight on this ASAP..Gotta drive this thing 30 miles back home this afternoon.
Bump...hoping someone can comment on this this morning.....seriously dreading making the run home (30 miles) in stop and go this afternoon with this issue....Anyone?
Bumping again....nobody has any idea on this?
I will update one thing: The dimmed D indicator on the dash was dimmed because I had the lights on.
Other than that - the issue occurred on the way home, multiple times, but this time during acceleration (slow -moderate accel) with no foot on the brakes, jerk occurred between 3-4th gears.
Please someone - help!!!!!!!!!!!!!!!!!!!!!!
Your looking at trans problems, plain and simple. You could have anything from a bent shift fork to a gummed up valve body to toasted clutch plates…Without a CEL theres not much to diagnose externally. You are most certainly going to be looking at a trans diagnose at a local shop and/or probably a rebuild. Sorry for the blunt delivery, its just that these transmissions don't often have problems..but when they do, its rarely something as simple as a solenoid(unless the CEL is triggered with a p0700 code). What year is your T4R? The 96-2000's aren't that expensive of a trans to find used, the 2001-2002…an entirely different story. (Ask me how I know)
Update: Took the truck to my service guy this morning, he test drove it and was able to replicate the problem.
Definetly the transmission...he said we could try a trans flush, it might work, it might not...otherwise, replace the transmission.
Being that this is a 2001 with 240k on the vehicle...2wd....what do you think? $225 for the trans flush, vs $3700 for the trans replacement....I am torn, and dont know that I want to put that kind of money into this.....
need some input....
Thanks,
Michael
