Have Auxillary Lights? Need Switches?? Check out this ORW Install Kit
It gets pretty bad when you have more than enough LED lights for our trucks.... This is a GREAT solution to gain access to ALL of your lights and within REACH!!!
Have 3 open holes?? Mount These Rocker Switches will fit into factory mounting holes (no cutting) or use the supplied install bezel (cutting is required)
Universal Legend Sheet
ORW saves you time by including enough wiring to complete the job.
K4 Contura Rocker Switch Package
10 Piece Kit Includes everything you need to install a three switch panel.
(3) Amber Lens Contura Rocker Switches - 14-522
(2) K4 Contura Rockers Switch End Panels - 14-585
(1) K4 Contura Rockers Switch Mid Panel - 14-586
(1) K4 Legend Sheet Black on Clear - 14-601
(1) K4 20 Feet 16 GA Black Primary Wire - 40-220
(1) K4 20 Feet 16 GA Red Primary Wire - 40-221
(1) K4 1/4 Female Crimp Connectors 12 Pack - 40-107-10​
Don't have lights and Need them?? Off Road Warehouse sells Rigid Industries, Baja Designs, KC Hilites, and many more!!! ​
NVBASSJUNKIE
