Have you had any problems with your 31M battery on stock charging system?
  • Total voters
    26
i guess it doesn't matter, i wouldn't want to buy anything that i wanted more than a 24-hr warranty from sears these days anyways
unless i can find a cheaper local odyssey dealer I'm comparing these two batteries:
Duracell Ultra 31M - $230 after rebate
(East Penn battery)
Cold Cranking Amps: 800
Capacity 20hr: 105AH
Cranking Amps: 1000
and X2Power Marine 31M - $ 350 after rebate
(Northstar battery)
Cold Cranking Amps: 1150
Capacity 20hr: 100AH
AutoAnything routinely has 20% off coupons, that's where I bought mine with free S&H.
I've read some mixed reports about people who have had issues with 31M batteries, they seem limited but I figured I would do a poll.
Follow-up questions:
If your battery died prematurely - were you doing occasional maintenance charging?
If your fender cracked - did you improve the mounting tray and tie-down for the larger battery?
Is anyone running other sizes of deep cycle batteries?
[MENTION=55815]Okki[/MENTION] memorably had issues with the battery draining down over a couple days, IIRC the issue was the stock alternator not keeping up with his electrical demands, maybe he can more adequately answer that.
Similar to Okki's issues, I have had an optima battery for about 1.5 years and over xmas it started having issues. Took it in to get it tested and two different places informed me there were no issues with the battery (bad cells, etc.) except it seemed that the alternator wasnt able to fully charge it up while running (one place had the alternator fail a voltage check, the other place said it was low but that it wasnt showing a failure). Bought a tender and used it a few times while i saved money to get a HO alternator. Got the HO alternator and got it installed last week and have had no battery issues since. Will make sure to come back and update if i have any issues but i can already tell the difference and singing the praises of the HO alternator.
the stock alternator will not fully charge the deep cycle battery, leaving it not fully charged will cause sulfation which will shorten the life cycle of the battery
so far based on the poll results it looks like ~monthly charging is sufficient to avoid sulfation
To clarify [MENTION=55815]Okki[/MENTION] 's Diehard 31m case cracked around the terminals, the same as mine, although his was much worse, and gel was pooling on the bottom of his battery cage.
From what I have deduced and tested it has more to do with not driving your truck far/long enough, not so much to do with the alternators output at least Trail editions anyway.
When I have been on road trips I have zero issues maintaining a proper charge, (running a fridge) I only live >5 miles from work, hardly even enough to warm the truck, I avoid driving, that is in no way sufficient to maintain a battery of this size.
aha! so that was it!
idk YMMV but i was having issues with my alternator keeping up with my demands. Or i have a short somewhere causing a slow drain? who knows? for now the alternator has solved my issues. And the HO alternator will help me keep up with dual batteries which are on my mod to-do list. Thats what i was mostly worried about, since i was having issues keeping one battery charged, it didnt seem like it would be able to keep up with two. Though if my alternator is hiding a larger issue, like a short somewhere, i should probably try to locate it or install a kill switch near the battery so i can halt all current whenever i park it for long periods of time. but i digress... :yield:
It looks like Duracell is made by east penn (deka), [MENTION=6163]phillyd2[/MENTION] is costco duracell?
this battery is a lot less expensive than the odyssey or X2 (northstar):
https://www.batteriesplus.com/productdetails/sli31dtmagmdc
I've been kicking around a few ideas possibly involving the National Luna Portable Power Pack (which I'd couple with a Group 31 AGM) - and I actually found that if you have a local Sams Club near you, they sell a Group 31 AGM (Duracell Platinum) for less than $200. Might be worth checking out, likely the way I am leaning.
https://www.samsclub.com/sams/durac...rv-battery-group-size-31dtmagm/prod3590232.ip
i looked at the power pack but don't think i understand the appeal, for about the same price you can get a real dual battery kit
Costco is Interstate Batteries (Johnson Controls) Been running them in my boat, all replacement batteries, and as my main battery for years and years. Never had an issue. I still have the OEM battery as my backup starting battery too.:bounce:
idk YMMV...
Of course as you mention it really depends on what your demands are too. The only serious continuos draw I have is a fridge (and I for obvious reasons only use it on trips). The winch and compressor are completely intermittent (the winch and fridge are the main reason for the battery)
You should grab a clamp meter and see what your truck draws when its off (they are not super accurate but give you a good ballpark figure). I did and sadly I can't remember what the draws was but it was enough to make a dent if I didn't drive for a couple of weeks.
My fridge draws a few amps when it runs, which depends on ambient temp. It shuts of automatically at 11.8V, with 100ah I shouldn't get that low
Sent from my P00A using Tapatalk
I would have to disagree with this statement. Power packs clearly do not cost as much as a dual battery system. I bought an Antigravity XP-10 for less than $150. You just have to shop around. Most dual battery kits I've seen cost upwards of $500-1000 without the spare battery.
With that said, I had my heart set on a dual battery system for the sake of redundancy, but have since changed my mind. First of all, I don't have a lot of lights to run. All I need an AGM for is my air compressor, winch, and fridge. I don't think the NEED is really there for two batteries. All those reasons and I don't want to mess with the installation.
Anyway, I haven't invested in a new AGM battery yet for my 5th Gen. My only concern is the fender cracking I've seen some people have issues with. In case you were interested, I found this blog post the other day which was pretty useful for me considering I don't know a lot about batteries and such.
https://five9341.com/2017/01/06/choosing-a-battery-for-your-overland-rig/
we were talking about the national luna power pack, its ~$500 without a battery, which you can buy a dual battery setup for. its really only useful if you don't have room under the hood for a dual battery, which is how they market it. the arkpak is similar but costs a little less, but it seems like there are some quality control issues.
from what i can tell the fender cracking seems to be people using the stock tray, spend $10 on a metal tray and i bet you can avoid the problem.
Ahhhh..... gotcha. Thank you for clarifying that.
My only hesitation about buying such a big battery is the cracking issue. Have you seen any other 31M battery trays aside from the Pelfreybilt one? I did find this.
https://off-grid-engineering.myshop...tery-trays/products/ml-acr-mount-battery-tray
i see no reason to spend money on a fancy pelfrybilt or similar battery tray, all you should need is a basic battery tray like:
$10 Steel Battery Tray 13"
(you'll also need to buy longer j-hooks which should be <$5)
i saw some that were even stainless steel and contained j hooks for about $20 on amazon. just make sure the tray is solid metal construction so it doesn't rock on the fender and that it fits the dimensions for whatever battery size you get (group 31 will need a tray about 13"x7")
although if you want that sweet overlanding credibility i guess you definitely need the pelfreybilt one
Thanks for the article. That was interesting. I purchased an odyssey battery that I haven't installed yet but hoping to soon. I got the steel metal battery tray from Remy which was not expensive at all. I feel like you can never learn enough about batteries.
I think I'm going to go with the Duracell Ultra 31 and use the cost difference to get a good jump pack. Its made by East Penn (deka) which has plenty of good reviews.
I contacted East Penn about chargers, the NOCO multi-prupose chargers were all too high voltage. this battery has a Charge/Absorption/Equalize of 13.8V-14.6V, the NOCO is 14.8V.
East Penn recommended Clore Automotive chargers, so I contacted them, they don't list the voltage in their manuals. I really liked that the NOCO was waterproof but I'll see what I can find.
EDIT:
The NOCO GenMini1 on-board charger should work
Didn't know of any issues...had a group 31 in the first 5th gen for 5 years and 120k....this one's been in the 2016 for about 15 months....20k. No issues I know of, but guess I better go check.
As far as power, first truck had a dual battery setup....never an issue. This one has single, and solar on the rack, no issues. Run a medium size Dometic about 8 months out of the year...24/7. I opted to carry a jump pack this time around.
Do you mind sharing how your solar is mounted and set up?
