Headlight adjustment after front lift?
coleb10
Tried to do a search but the page never loaded on my computer.
Recently raised the front end of my 4th Gen about 2 inches with adjustable coilovers. The projection of my headlights appears to be higher now. I say high because the cutoff of the lights seems to be higher than before.
On several occasions when I approach a car from behind at a traffic light my lights are right in the drivers rear view mirror and I can sometimes see their faces. They often shield their eyes with their hand or adjust their mirror to deflect the bright light. Last night I drove up behind a car on the highway. They were going a little slow so I went around them. Plenty of space and clearance and within the speed limit. They then proceeded to repeatedley flash their bright lights at me.
Is there an adjustment I need to make or is this normal with this type of modification?
These are higher than normal vehicles and maybe this is just how it is suppose to be. I have no headlamp modifications. Thanks in advance.
headlight adjust
Dude know I saw a cpl pics here or maybe T120 but its pretty simple little plastic nut you can see looking down on the back of headlamp 10mm takes a lot to bring it down had the same issue damn sorry I can't find that thread ? Sure some of the long members will hit you up .
Headlight adjustment knob
Opened the hood today and found the adjustment knob. Pulled it up close to the garage and projected the beams on the door and then lowered them a bit. Will see how that looks.
Pretty much what I did. I don't have time to get all technical and ''perfect''.
