Headlight Housing Question
Staceman
Hello, I cannot find my answer in the FSM. I would like to remove the glass cover on the headlight housing to clean/polish the inside reflector surface. 2000 4Runner with a milky haze on the surface. There are 2 small clips on the top, are there more around the perimeter? Is that glass even removable? These headlights are pretty dim. Also curious if the diffuser/bulb cover can be removed and if that would help as well. Thanks!!
Read through some of the HID projector retrofit DIYs. You have to bake the light in the oven to soften the sealant that keeps the lens on the housing. I've never done it myself...
