Headlights on
Well I had a witty reply to the comments of us snobbish LE owners but after reading "Antmans how to on DRL's" I just can't think straight anymore :confused: :)
OP, sorry I have no help to offer to you other than maybe have the dealer take a look. Best of luck!
So basically you want the headlights, fogs and DRL's on at the same time. It wouldn't be easy to to this with the DRL switch itself, but if you do my fog mod, and the DRL mod it would be basically the same thing. Just put a switch for the ground wire on the DRL mod.
You will have independent control over headlights, fogs, and DRL's. The problem is the DRL switch on the stalk breaks the circuit when you turn it to "headlight".
I guess you could use that ground wire to switch relays for the fog mod, and a relay to turn on the headlight circuit. That should work. Confused yet?
If you want to definitely do this, PM me and I think I can draw it up for ya. :)
since we are on topic of things being simultaneously on..
Would you think there is a way to disable the link between foglights and high beams...easily..?
Not really. The relay that makes it all happen is in the black box under the dash sealed up. The foglight mod isn't hard though(?). :)
Ambrose67
