Heater only blowing cold air!!!!
Dog5911
Junior Member
This morning on my way to the office I noticed that the engine had reached middle of the range on temp gage so I was excited to get to turn on the heat and warm myself up. This morning it's 20 degrees where I am at here in Arkansas. The blower motor was replaced few months back and it blowing strong so I am not thinking that it's the issue. 2008 4runner 4x4 sr5 with climate control. Any help or suggestions of stuff to try or check would be more than welcome. Thank you in advance!!!
What was your temp set at ?
Sometimes mine seems cold (73) but then I turn it up a degree or 2 and then it goes warm again.
are the Qty-2 heater tubes plumbed into the cab (located up near gas pedal) from engine compartment hot to the touch? if so, sounds like your blend door actuator is malfunctioning or stuck.
That is something I need to check, but I am stuck at work for while longer. How hard is the blend door to access?
I've noticed mine is a little squirrely as well on my 07' Limited. I can here the blend door actuator motor incrementally positioning the blend door from Lo to about 72 deg. Then from 72 deg to Hi, I no longer here the actuator motor working. Since this is a electronic climate control system with thermistor , I'm wondering if that has something to do with it. I do have heat though, so no complaints out of me up here in Chicago. I'll dink around with it in the spring!
Right now mine is blowing hot and I am not ready to chance it and test to see if the blend door is working or not
Same problem
I just tried my heater for the first time since I bought the care and it is only blowing cold air as well. Did this problem stay resolve? I know my blend door makes a sound for about 10 seconds every time I start the vehicle up. My fear is its a heating core. The black tubes going into the firewall get hot when I let it idle.
