hello all :)
zako
elo all im new to the forum and new to yota's also .... im from the uk and a few months ago i was in need of a vehicle to pull a trailer for work so i found a manual 1994 3.0 td 4runner (mechanical injection)... went to have a look at it and took it for a test drive and i was amazed and bought it right there and then ... its done 150k engine sounded sweet and having read up on them they will last 250k +... here in the uk is the first in a few years we have had some deep snow (well where i live it was 6-8 inches the yota had no problems i even overtook and quite annoyed some land rover defender drivers 'stuck' :eyebrows: mmm welll so on with my story.. i was going to change the filter and oil as soon as i got it but being as ive only owned little cars and not trucks the tool i had to remove the filter was too small and by the time i realised i already drained the oil hah so its just had new oil, it had a few pieces of rust mainly on the boot door... being i live in the uk there are not many 4 runners here so there arnt many parts so i went to my nearest scrap yard and found a surf stole the boot door from it and today i stuck it on the back of the 4runner :D...
i have a few questions now:
i have noticed a rattle coming from about 1500rpm -2000 cant figure out what it is it gets faster as the revs go up im thinking turbo but i havnt noticed any power loss what so ever and its not drinking oil or water. the last timing belt change was at 59k so it may be a worn belt.
also another common fault i've read is that there are rear boot window problems.. yes i have them but it goes up and down fine but there is about half a inch gap where it doesnt go up all the way :croc: any ideas?
and how can i tell if mines had a body lift ? whats the standard height and where do i measure from.. mine seems quite high
ill upload pics of my beast shorty :) and thanks for reading my long winded story :wave:
Welcome!
as for your noise i would pop the hood and rev it with your hand and listen to find location and then we may be able to help some more.
window dose it make and grinding noises when it get to stoping point? may need a new motor
body lift can you put your hand between frame and body? if so yes if its tight nope.
and is the engine turboed?
I knew it was a Turbo Diesel when he mentioned "mechanical injection" also the "td" after the 3.0.
Anyways, Zako welcome to the forum!
Cheers!
