HELP! ABS light and no AC or windows working
[MENTION=83083]rigtec[/MENTION]
Issues: no power windows on any controller, and no power to fan/AC controls.
Resolve: 10A fuse ECU 2 replacement.
If you need I can take a pic of the exact fuse.
the rule is disconnect the negative battery connection before you work on the dash . reason is the air bags as well as fuses can blow or other stuff. it does happen and the air bags are expensive.
Not to mention, if you're unlucky enough to probe or tap into an airbag wire and the airbags go off, they can seriously injure or kill you or anyone else in the area.
[MENTION=92546]MadeInMaine[/MENTION] , I'm glad you got it figured out.
jisoo200
