Help/advice needed. Low compression in '01 v6 w/ 110k. Mechanic says needs Big $ Fix
cab415
My wife's 2001 SR5 4x4 v6. 110k miles. Bought it just last year with 100k. One owner, had all the scheduled maintenance done (and documented) by the dealer. Including the timing belt right at 90k to give you an idea of how complete it was.
Last week, the check engine light and VSC lights came on at the same time and the engine started running rough. My wife asked me to check it out. I drove it a few minutes and new there must be some misfire, so had it towed to my mechanic.
He checks it out, rules out a couple simple things like spark plugs, and does a compression test. Here's what he told me:
"Cylinder 6 is at 60lbs vs. the others at a normal 150-160. The cylinder head will need to be removed to be inspected by a machine shop to determine what has caused this (possible causes: burnt or sticking valve, valve guides or a problem in the camshaft).
The labor time to remove and reinstall the cylinder head is 15 hours. On top of the labor, we will need a head gasket set, the replacement parts of whatever is causing the low compression, fluids and machine shop costs. The machine shop recommends inspecting both cylinder heads with any engine over 100k miles but that also means another 13 hours worth of labor to remove and inspect that one."
We're talking about a few grand in work ($3k at least at his rates). Anybody have any advice or suggestions? Is this really the only solution from here? Do you agree I should spend the $ to do the other cylinder head, too? From everything I've heard about this engine, I'm just surprised there would be such a major problem with just 110k miles, especially considering how well it's been maintained.
Please help! Thanks!
I had a similar problem but on cyl #4. i knew it was either an injector or a valve before i brought it in to the mechanic. He was able to re-shim the valve to bring the compression up to par. and I had a new injector put in
it was $1300 for all of that, so your mechanic if full of himself on his price. I would go somewhere else. You know this kills me. we are in a bad economy and people are charging through the roof for stuff
28 hours for both heads? Run away from that shop as fast as you can. Get a second opinion. The published labor time to R&R both cylinder heads is 10.0 hours. The published labor time for a complete valve grind on both heads is 17.1 hrs. He shouldnt be charging you extra because hes slow. FWIW I would feel completely comfortable doing only one head on a 100k engine. As J-money$$$ experienced it is extremely likely to be a valve issue. Nothing major at all. Call around, let people on here know where you're located and maybe we can point you in the right direction. Good Luck!
Oh and those labor times are from mitchell on demand in case it comes up. Not sure what No-data calls for but theyre usually the same or really close.
Thanks for the quick replies.
I'm in the Bay Area (North Bay) in case anybody on here can recommend a good shop. This is my first experience with this shop, and my first 4Runner repair. My old mechanic, who I loved, only worked on Jeeps; when I switched into a 4Runner, it was time to find a new shop.
