Help Choosing a Telescoping Ladder
Iron_Will
Hey guys and gals,
I'm building the back of my 4-Runner out into a home, and I'm moving to Nome Alaska next year to mine gold for 2 - 3 years. I'll be living out of my vehicle during the summer while on the beach mining sands, and I've got a really nice build going (not GLAMOUR, but functionality). I'll describe the build, but first I need help...as the title says...choosing a telescoping ladder for reaching a Thule large container up top.
I'm 6'1" and about 250lbs (for ladder reference) and my Prinsu roof rack is 6.5 feet from the ground. I've noticed the side of the 4runner arcs out which means the ladder will need to be planted a few feet away, so that it leans onto the roof rack without hitting the vehicle. I've never used one of those type ladders, so I don't want to get OVERKILL and have one that is way too big (as I'm trying to minimalize). With that being said, I don't want to "under purchase" and get one that is too weak . I know a lot of you have experience with this sort of thing so I am turning towards your advice. I appreciate any help you can give me with it. (I'll probably be purchasing from Amazon for it)
NOW for the build...
I'll do a walk around video with pictures to post here once its done, but for now I'll describe what it has.
- 27" x 72" bed platform (3" more length at the head totaling 75")that lifts one half into a reclining position for reading or laptop. At the hatchback end it has a 3"dpth x 24" wde x 28" pull out draw with a sliding cutting board.
- left of the bed at the hatch back end is a double decker drawer housing a camp stove/pans, bowls, utensils. On top of that is a 24" shaped top that holds a microwave and rice cooker.
- On the right side back door I have a 11 gallon frontrunner water tank with 12v pump to an attachable (via roofrack) 32" circular shower w/shower curtain.
- On the left side back door I have a 3.2 cubic ft 2 door mini fridge/freezer.
- Also between the fridge and the camp stove drawers is a 7,200 watt Eco Flow Delta Pro power station w/ two 400 watt solar panels.
- I have two 5 outlet power strips, each with individual lighted on/off switches
- Battery Tender hooked up and turned on with flip of a switch at any time supplied by the power station, if sitting for 1-2 weeks without going anywhere.
- 3/4" plywood ceiling shelves and mounting purposes with a perimeter string lighting
- Various shelves once I see how much leftover space is available.
I'm currently about halfway done, and a few things I'll have to get my cousin to help with (he's a mechanic and car restorer). One of those is that rear hatch opening switch that I read by seantrewick on here. Thank you for that build. I sure hope I don't mess it up.
Anyway that's all for now, and thanks for any info given,
Iron Will
Any telescoping ladder will work and then I'd recommend fabbing up some sort of bracket that attaches or provides a stand-off from the rack. I currently use a ladder with my RTT which is maybe 1.5-2" proud of the side of my rack without problem.
:wave::yo:
K thanks
I would like to see this when done and good luck. How did you choose the 7,200 watt Eco Flow Delta Pro power station w/ two 400 watt solar panels? Do you have experience with this product?
I researched each company best I could and reviews as well as versatility for watt I needed (pun intended). It charges faster than other power stations, it was right there at the top of reviews with Blueetti, and Jackery, but it was on sale for the machine and extra battery. I have really only used it in a limited capacity with battery chargers for drill and skillsaw (since I bought it in March this year), so it hasn't gone through the stress test yet of continuous use or solar charging and such. But to answer your question no...I have no experience with any power station products.
Concerning the build I'm about 80% done with it. :banana:
