Help!!! CV Boots gushing!!!
so I bought some metal hose clamps with the screw on head . I also cleaned the CV but how do I slide it off to add more grease before reclamping? The existing metal clamp is still on though a little loose as I can slightly squeeze the boot and a little grease will come out.
Sorry guys I am so unmechanical! I am usualy the write a check guy but I just spent 1300 in mods this month already!!!!
I have the same question... if anyone could answer it, it would be much appreciated!
Thanks guys. I put on the hose clamps ( the screw down kind and it has slowed it down but did not stop the leak all together. Should I at least drive it until it starts making noise??? Or should I take them off and try to rebuild them with the help of a friend. Anyone around Yucaipa- San Bernardino want to help a newb? That or buy new ones and try putting them on. Is there a write up on installing new ones??? I have a few tools but am far from mechanical but I heard this isnt too hard.
Dave
After my stock CVs leaked almost all the grease out, and after the hose clamps eventually failed and tore into the boots, I duct taped them all back up. Then they completely shredded a few months later - all as I drove through a snowy winter using 4x4 a lot. And then I swapped em out the following summer because they were almost bare bones with a little bit of boot left here and there. They never did fail or even make a noise, so you're not in any imminent danger by an means. You could probably go years before one fails because of leaky boots.
I think it was like 170 ft lbs or close to that. My buddy just stood on the breaker bar and he weighs about 170. If you have a good torque wrench, it's not a bad idea to use it.
Hey, no prob. Making sure is always a good thing to do. I have heard of people using 1 3/8" standard sockets as well, but I went with metric since everything else on our trucks is metric. I have also heard that some have used a 34mm socket, but I didn't want to take a chance of it being too small. It's better to be a tiny bit too big rather than too small to fit on there.
I do have a good torque wrench, but I don't think it goes that high. Damn, gotta buy another one.
I 'm going to order a 35mm socket today.
Thanks :cheers:
just want to give a gentle nudge towards doing this if your replacing the boots, if your just tightening the clamps up i wouldn't bother....
my plan is to get some oem cv's and do this boot mod and install them then keep my mastercrap ones from the flaps as trail spares.
Boot Slide With No Glue - TTORA Forum
BOOTSTOP3.jpg~original
PRWhite
