UPDATE! DO NOT DRIVE YOUR CAR IN WATER!
Well the mechanic got the ECU installed but could not program it correctly so I had to have the car towed to the dealership and they found all sorts of other problems:
-Program the ebay ECU- it works!
-Clear all of the error codes(it threw all the codes on the dash)
-Replace the 02 sensors-water killed em
-Make a new key(I got the car used with only the valet key apparently)
-The idler pulley bearings are bad from water intrustion
All said and done im gonna be in $1500 with a used ECU!!:mad2:
I think what happened is that water got above the doorsill and came inside the cab. It shorted out some wires and fried the ECU as well as destroying the bearings and o2 sensors.
