HELP! flasher/signals not working.
Kev4runner
my signals are not working at the back, and i checked the bulbs and i tested them with a multimetre and it is working fine, but when i signal its not working! wiring problem?
The blinkers in front work, but not the back? And the bulbs are good? Stick your meter on the contacts in the sockets, see if you've got voltage there. If not, trace it back.
if I remember correctly there is a single point ground for the rear harness.
Do the running lights and brake lights work?
Noticed my turns are not working... Front or Rear not working... Tail lights and reverse lights work no signals and no hazards..... :ybrick:
Any suggestions?
Any suggestions?
Does the horn work? If so, I've got 5 bucks on the flasher relay. In the drivers kick panel if I remember right.
Since the hazards and turn signals use different fuses, the common factor is the flasher module. It's located above the fuse panel that is located behind the drivers side kick panel, and it's green.
