HELP im at my wits end with my daily driver.
i dont know if you want it spencer ill cut you a deal with the frame sliders and the engine so you dont have to make multiple trips
Lol I don't really need it just wondering I think I might swap to a 7mge I can get for.cheep
7M-GTE if you really want power, use a 5mte clutch, the w56 transmission and housing with the clutch fork from the 7m housing and a 5m TO...ask me how I know :)
if you are serious abotu doing a 7m/5m swap check with supracharger.org, that guy is the KING of swaps into 1st/2nd gen 4runners (he did mine)
dont have the cash for that unless someone scraps a supra in the take a part.
You can do the swap for on the cheep, find a supra thats been wrecked or out here in CA that can't pass smog and you can get it for under 600 bucks...
BUT...I will say this too, while I love my turbo beast, sometimes its TOO much power. Like in the rain, getting on the freeway, if I am not light on the go button, it will light up the rear in 4th gear and pull me sideways down the freeway. Ive even lit it up in 4Hi in the rain, all 4 wheels in 2nd gear spinning down the road.
im looking for a 22re (as u now know) but im no master tech and am not sure i could get it to run right if u havent been able too.
o i solved that issue the ECU fried and took harness with it, i decided the body wasnt worth keeping around so i parted the truck out.
it would be drop the block in and go if your computer is good.
your the man. im starting to realize i have alot to learn if im going to keep this 85 in the family as long as i plan. hows the white runner doing? i look foward to seeing more of it.
slowly coming together once the 3.0 is running ill trow the interior in finish painting and be running around with it.
Deelock
