Help pls. How do I change driving lights
Gecko123
Hi
I have a 2006 limited. How do I change the driving lights/fog lights bulb. It looks like I just pop off the plastic cover surrounding the light, etc., but I want to make sure so I don't break any thing. Or is accessing the bulb from the backend?
You change it from the back. It's usually easiest to unplug the wire from the bulb (by pressing the little tab down and pulling) then rotate the bulb to remove.
A lot of people wear gloves when they change bulbs, it can be done without it but make sure that you don't touch the glass of your new bulbs or it can significantly reduce the life.
youngrk
