HELP! tranny problems
tomasone5
Sooo had a rough weekend and went into the wrong mudhole...anyways long story short got it pulled out and everything but now whenever I engage the tranny into drive reverse or any gear the transmission almost isn't recognizing it and doesn't move...I had a buddy that had the same thing happen to him and it turned out to be a sensor...can anyone shed some light on what I can do or what the problem may be? What/where to check? The engine was pretty submerged when it was in the hole and the wheels were moving and everything on the friday but when I went out saturday I had no luck with getting it to move in any gear....HELP PLEASE!!
I'm guessing since you said "drive" you have an auto trans? I'd check your fluid and if that looks okay I'd look at your linkage next to make sure nothing is bent under there.
Mike Sargent
