Help!! VSC Trac, VSC Off, & ABS Lights On
I know this is an older thread, but my brother is going to remove the XREAS from my 07 4runner sport and replace with FJ Cruiser springs/Billstein 5100's in his shop. He's the best mechanic I know so I have no worries BUT should we unhook the ABS connector to make sure a tear of the wire does not happen? Or, just be really careful not to overstress the wire? I had a front half-shaft replaced a while back with no problems so my local mechanic must have been careful with the ABS wire.
Thanks!!
Thanks!!
You can remove the line/bracket from the upper control arm, it's just one bolt. With this done, there's enough slack to move the line out of the way, and since it's disconnected, you should have any issues with stressing it.
I put in Billstein 5100, OMES 895s and CVJ axles. Now my VSC Trac/off and ABS lights are on. Hope I can find the tear. I was pretty rough doing the replacement. Thanks for posting this info!
Is replacing the sensor wire pretty straight forward?
I'm getting the "VSC Off" light blinking, Traction Control light and CEL, but no ABS light. I must have over stretched it putting new springs and shocks on the rear.
Well... it turns out my issue was gas cap related. I stopped by O'Reilly's to have the codes read and cleared. I still can't believe that I swapped out the springs & shocks and the warning lights are related to the gas cap. Odd timing. The gas cap issue makes sense only because our last fill-up was in Oregon, where you can't pump your own gas!
Hey [MENTION=44866]ARK_SWAMP_RIDER[/MENTION], did your dash look like this picture?? If so.. i think this will help nail down what i am seeing... although mine is coming on while driving randomly..
I have the same lights on mine! I tried a zero-point calibration, but the vsc and abs lights blink back and forth and if i start it again they come back as they were before. Am I just doing the calibration wrong, or is the actual abs wire damaged?
I remember reading somewhere depending on how it flashes, it tells you which side is damaged. Anyone have an idea where that information is?
matisgugle
