Help W/Fog Lights WTB:
aball4Runner
So I bought OEM replacement fog lamp assemblies. I am told I need relays and a switch. I would like to buy if you anyone has available. If you have any install insight please let me know.
FYI: My T4R does not have fog switch on Turn/Lights Stalk.
I also need clips to mount cross bars to factory rails on my 99' Base T4R.
its fairly easy to run 2 wires into the cab and add a little switch on the dash and just add a fuse from power to the battery
And don't go any smaller in wire gauge than your fog light assembly wiring..A 30 amp relay should be sufficient for the application..as for the switch you can either buy from your local electronics store or get the OEM Toyota switch for a more factory look.
Use this illustration for reference
relay-diagram_small.gif~original
Help needed finding a turn signal harness connector
New to the forum, but not able to post a thread yet. Turn signal fuse keeps blowing on used 2001 I just bought. Found Driver side turn signal connector that plugs into bulb socket gone, they just pushed the pins on the bulb socket. Any idea where to find the part number?
As Elton said, make sure to run a relay. Check if you have a spot for a relay in the fuse block under the hood. If your rig is prewired from the factory, you can tap into the existing wires for your new lights.
My '01 doesn't have a switch on the stalk either, previous owner installed a switch (p/n 00550-35976) on the dash.
PRWhite
