Help with a trailer for 3rd Gen
If you know anything about trailers, trailer suspensions and axles, could you lease take a look at my post in the general discussion area -
http://www.toyota-4runner.org/general-discussions/208239-help-camping-trailer-build.html
I have not received any replies so I am trying to get it out to a broader group :noidea:
If you know of a better forum or resource to post the question to, please let me know, thanks - Chris
There's a lot of experience and info over on Expo for trailers....Expedition Trailers - Expedition Portal
People swap to spring over axle all the time to gain clearance for off road use.
I'm building up an old Sears farm trailer. It has a 2-inch square (actually C-channel) axle that is rated for 1500 lbs.
Regarding spacers, I run them on both my 4Runner and my trailer. I have a set of adapters that converts the original bolt pattern to 6x5.5 to match the tow vehicle. It turns our I needed that extra offset too, due to the depth of the toyota rims.
As my camp gear is probably less than 500lbs and my trailer is about the same, I ended up swapping out the leafs for set of older 4Runner leafs and then added shocks. I found that the original 1500lb rated spring pack was far to stiff for offroad use, considering the light load I was carrying. It sucked getting to camp and finding that 10 of my canned beers had popped due to the rough ride. I now drive a bit slower with trailer too:happy:
Good luck with your project.
Take a look at @MTD's build thread. He did a M416, it'll give you some ideas, and you can probably ask him some questions about his build.
Thanks for the responses, that expedition portal has some great build information and @MTD and Dirtco's trailers are both beyond awesome and unfortunately beyond my skill level to construct. Been a pencil pushing kind of guy my whole career, would be nice to learn to weld!
I bought a set of leaf springs from a 95 wrangler and welded them on my utility trailer with a spring over. Used the shocks from the wrangler as well. Works pretty good. was able to source the parts from craigslist and quadratec
DionicioLives
