tysauce
I'm sure this topic has been beat to death, but wanted to hear some advice. I recently had 5100s and OME 885 front springs and 895 rear springs installed. Provides a 2.5-inch front lift and 1.5-inch rear lift. Also installed new 275/70/17 tires.
I had them install new UCAs and LCAs, though they are NOT aftermarket, just replaced with stock, non-rusted, options.
It was installed at a 4x4 shop and when they were done, they completed an alignment. The tech said he got it as close as he could within spec while also trying to save on the handling. He did note the camber was a little off so I might notice some slight premature wear on the outer edge of the front tires, but said it was small enough to not be a concern with normal rotations.
After the lift has settled over the last couple months and 500+ miles I took my 4Runner back to the shop to have them perform a complimentary look over/re-torque/test drive to make sure everything was still good to go. I thought maybe they would realign it now that it settled to bring the camber in, but they said all was well and looked good.
I guess my question is, do these alignment specs seem okay?
