Help with Check engine light codes.
Deputy1211
Got the codes read at parts store for my 2001 4runner (2wd V6) as the check engine light and TRAC VSC lights are on.
Test showed P0420 and P0171
Vehicle has 137,500 miles on it. I've recently changed the spark plugs, oil, fuel, air, transmission filter. Is this a problem with the O2 sensor? Haven't changed it since I've had it. Don't know if its ever been changed. Located both of them while under vehicle today changing the oil and am wondering which one (front or rear) would be better to change if that is the most likely avenue I should take towards clearing the light and fixing this problem.
Any info or advice is appreciated and I'd like to hear from a few different folks who've had this issue or experience with solving it.
Matt
They could both be related to the exhaust sensors (a/f sensor in front, if cali spec, and O2 sensor in rear). I would clean the MAF sensor first and see if that clears up the P0171. The P0420 is commonly solved by replacing the rear O2 sensor.
Talyn
