Help with front shaking/vibrating at highway speed
Uknome
Help with front end shaking/vibrating at highway speed
Just replaced front sway bar bushings with moog bushings and have noticed sterring wheel shaking while driving at highway speed about 70mph. Also had the font rotors and pads replaced. Brought the truck to the shop and had the front wheels rebalanced and still have the same problem.....any ideas?
Did you get it re-aligned after the repairs?
tire balance.
sometimes it's just the way the tires are worn. Rotate them and change the tire pressure and see if that doesn't help.
Thanks all... Plan on doing the fj and 5100 swap next week so i will get it realigned then. Rotating the wheels back to the way they were isnt a bad idea either....cheers!
