Help with lift
05RedRunner
i have a 05 4runner that is mostly stock, i had add a leveling kit to the front and air bags to the rear. but now i need to replace my shocks, so i went wit the bilstein 5100s shocks, i also am running falken wildpeak at3w 265/70/17 and have a lot of fender rub went backing up. what setting should i use on the 5100's i also have (not installed) 1 1/2" spacers for the rear.
You have a 1-2 inch hockey puck/ body lift in front? By fender run you mean your tires rub the liner?
265 70 17 should just about fit without a lift. What wheels are you running? Are they set wider out from stock?
If you’re running spacers there’s no easy answer - you may rub no matter what, but should probably shoot for around a 3 inch total lift
Even with a 2-2.25" lift and those size tires I rub with 1.25" spacers. It's not a big deal and just requires a little front bumper trim and fender liner push back. The spacers are likely going to cause it no matter the lift you get from the 5100's.
DionicioLives
