Help with rotors
sbsponger
I just ordered some new rotors and one side of one of the rotors looks a little bit thinner the other side. Is this normal?
Not sure what you mean...?
Like if your looking at the edge of the rotor, and there is the gap, one of the FACES of the rotor is thicker than the other...?
**Edit- Regardless, they should be the same thickness, but if they're REAL close, I wouldn't sweat it. Also, 'a little' is a relative term... If it's a millimeter off, it's fine. If it's 50% smaller, I'd be getting a new one.
I ran into this issue with rotors ive purchased from napa. They said it was due to the manufacturing process, will have no ill affect and would be ok to run. I wasnt very comfortable with that response but used them. They worked. But I still didnt like the idea.
allcarhistory
