Help with these objects!!
SacredPRO
Here are some things that I buy in a short time (I hope you can listen to their advice before buying any of the following items) :
Oxygen Sensor DENSO:
31-50E5zP0L_SS500_.jpg~original
Brembo Brake Disc ( These are better than OEM quality?)
W01331622988BRE.jpg~original
Fuel Filter V6 3.4L Genuine OE OEM
toyota_4runner_1997_fuel_filter_oem_127_51_009_12751009.jpg~original
K&N Cold Air Intake
imagesqtbnANd9GcSF81QdyaZl7EyZBmrLVMJZCPFtXZc9GWUbLTask6zOCqQ2M7MARY38S9Nm8Q.jpg~original
MAGNAFLOW CATALYTIC CONVERTERS 51006 (Buy a replacement but alparecer not of good quality and not worked for me so I want to try one Magnaflow brand.)
KGrHqJHJFEE-k-JDjY8BPuWd7FG60_12.jpg~original
MagnaFlow Muffler 22" ( I need help with that because i want a Muffler with the OEM size, What size do you recommend?)
104096-rear-cats-removed-magnaflow-muffler-22-magnaflow-001.jpg~original
Brembo Calipers Cover :P
KGrHqZhIE7SiO3B2jBPmT6g61Q60_57.jpg~original
Hella Fog Lights ( The OEM dont work good with HID)
KGrHqJlwE9JVDGL29BPSoeu9zQ60_58.jpg~original
I hope your advice and I also have some experience with some of the articles, Thanks for taking a little time with my 4Runner. Greetings! :biggrin2: :biggrin2:
Here is where I can help you:
For the oxygen sensor, Denso is good. Get it off Amazon.com for the best price.
For the brake calipers and rotors - ugrade to the Tundra calipers and rotors. A lot have already done that on this forum and are happy with it.
Cold air intake would be up to you. It will help performance slightly and change the sound of the intake. Not really something I would see as necessary to put money into but to each his own.
For the cat, exhaust, and fog lights, I don't have much experience there. Sorry.
Toyota Tundra with the same year my 4Runner?
Assuming you don't already have stock fogs? Maybe post some detail about your truck (year and trim style specifically) so we have an idea of what you're looking at.
I did the Hella fogs a couple of months ago. See if this helps:
http://www.toyota-4runner.org/3rd-ge...nal-stalk.html
1998 Toyota 4Runner Limited V6 i have OEM fogs lights but dont work with HID, I just saw the link you posted and that is exactly i want to do, install add Hella Micro DE with HID Sytem, I'll use your post as instructions THANK YOU! = D :frisky: :biggrin2:
Here. Find the proper O2 sensor for your truck..
Oxygen / AFR Sensors - Underdog Racing Development
K&N is a bad buy, dont do that.
Info on tundra brakes:
http://www.toyota-4runner.org/3rd-g...m-13wl-tundra-calipers-rotors.html#post835439
What is the difference between the sensors if they look exactly alike? anyway I'll buy the exact model that indicates the guide in case you change into something I do not know.
About Air Filter K & N just want to use the investment as I replace the one I have now, in which case you recommend me buy the OEM filter??
Thanks for the Post of the brakes, you could reupload the photos? Thanks
