Help with trouble codes
jcruiser70
I've had some trouble codes for some time, went to autozone, this is what I got:
C0205 abs left front speed sensor
C1201 engine control system
C1210 zero point calibration
C1223 abs control
C1336 zero point
P0346
It seems I may have a bad abs sensor, I replaced the cv's a few months back and have had the code since.
The p0346 is the camshaft position sensor, the car runs fine with these codes, but I'm going blind from the lights on the dash!
I've searched but can't find much on the p0346. I believe the majority of the other codes are the byproduct of the 0346, but am unsure where to start for sure....
Any help is greatly appreciated!
I might start with a zero point calibration only because it's not a physical repair and see what happens, you can find instruction around here somewhere.
Then You can attempt to clear the codes by disconnecting th battery for a while and see if they all come back.
But it's easy to smash the speed sensor during a cv replacement. The wire is microscopic.
Thanks, I'll give the wires a good check over. I'm not finding much info on the p0346, it says the camshaft position sensor for bank 2, is there some way to test the sensor?
johnnya
