Helpful hints passing speaker wire to doors ?
wahoossi
I changed out the JBL system and now have a Kenwood DDX 371 with infinity speakers in the back doors and upgraded JBL speakers in the front doors. I have a dedicated JL JX 250 1 channel amp in the back with a 7 inch JL subwoofer (copied from one of the great guys on this forum who posted his build thread). I have a JL JX 360 4 channel amp dedicated amp to power the door speakers. I have run the power lines directly to the battery, grounded the amps to the body run the input rca cables to the amps from the head unit. All I have left is to run new 12 gauge monster cable from the amps to the door speakers (subwoofer done) and hook up fuse to the amps. This is where I am a hung up. Does anyone have any tricks on getting the wire into the doors ? The rear doors look doable but the front door wiring harness appears to enter from the back of the dashboard . I guess I could approach it backwards once I drop the door panel and send a fish wire through the rubber gasketed wiring harness sleeve, hope it comes out where I can see it, then hope I can pull the wire (pretty thick) through the tight access sleeve in the door. Any better ideas?
Another question I have is about the remote line to the amps. I assume this what is used to tell the amp to power on and off when the car turns on and off. Right now my head unit is dropped and I was going to attach both remote lines to the auxiliary 12v wire of my headunit. I assumed this was a live wire because there was another wire attached to it. Is it ok to hook both amp remote wires to the same wire . I will test it before I put the headunit back in . Thanks for the help.
Hard for me to remember from when i did my remote wire but i think its the gray wire on the factory harness going to the radio
I answered one of my own question, the amp turn on is the blue/white wire. Now to attempt to run the speaker wire. I guess I can run both amp remote turn one to the same turn on wire?
With the door panels off, I think there are 2 bolts that hold the harness on the door, lube up the wire with wd40 and pass it through. 12 is overkill but 16 is fine, another tool to use for wire fishing without damaging paint is use a long ziptie. Is the new amp going to be under the front seats or in the back.
Thanks. I was able to get it through. You are right, 12 gauge was ridiculous . One amp went under front seat, other on shelf in the back. Everything works but now my rear view camera stopped working . PIA.
Philthyphilthy
