98 LTD is having serious loss of power issues. Recently gutted the cat and changed fuel filter when I initially noticed slight loss of power. Soon after a misfire appeared, not sure which cylinder I simply replaced plugs and it went away. However loss of power has continued and become worse. When engine was misfiring it would occasionally throw a CEL which would go away, usually a flicker. Put a scanner on it and no codes and misfire did not show up on scanner even though it was indeed misfiring. Buddy has repair shop and scanner is top end unit. Currently planning to replace both 02 sensors and cat. Also going to check fuel pressure possibly do compression test. My current theory is a lean condition brought on by either bad sensors/false readings from post cat sensor or weak fuel pump. Any other ideas what would cause a hesitating/surging loss of power?
Symptom is is a very rhythmic hesitation/surging with low power and engine accelerating in short rhythmic surges.
Thanks for any advice or help.
