High lift jack mount without a welder. W/lots of pics.
ellner357
Well being a 4x4 guy without a welder (I know sad right) but I am not without resources. So I was at an industrial plastics and paints shop and decided to try this out.
What you will probably need
-M8x1 ready rod (I used the highest grade they had)
-8 matching nuts (there's a few extra but I always lose one somewhere)
-6 body washers
-two wing nuts
-3.5" tall 2" wide hard plastic bar of any kind.
-2 x 10mm wrenches
-hack saw or other cutting tool
I got 3" tall 2"thick plastic stock. I would use 3.5 if I did it again because it's just a little close on the drivers side. I could take the foot pad off if I wanted we will see.
3ujapa5y.jpg~original
Okay on to the build.
I started by taking the stock mounting bolts for the tie down points off. Now for me that wasn't so easy one of mine snapped. So I ended up drilling it out and using my tap and die set to save the threads.
The easy out style bolt remover didn't work so well...
gavunyhy.jpg~original
quge8u6y.jpg~original
A hard one battle lol.
ydyzuvyr.jpg~original
So then in goes the ready rod, toss on a washer and a bolt to keep it from backing out of its hole.
20130227_182008.jpg~original
Very important not to drill the hole on the side of the foot pad centered if you want the jack to sit nicely. I also drilled a larger hole with a step drill at the bottom so it would sit flush over the retaining bolt. Slide it all together a washer and a bolt on top of the plastic rod then on goes the jack a flat washer and a wing nut.
20130227_183040.jpg~original
20130228_101210.jpg~original
2u9apy4e.jpg~original
20130228_101202.jpg~original
20130228_101149.jpg~original
waterman2258
