Highest Mileage 4th Gen?
New to the forum,
Looking at a 07 sport 2wd with 287,000 miles on it.
Car lot is asking $4400 with tax title and license.
2 owner clean carfax, highway miles, drove wonderful!
Is it worth it?
Purchased an 03 a few months back with 210,000. Already did a short road trip and some treks to the mountains. Trying to get to 300k.
Picked up mine a month ago with 380kms on the clock. 2UZ-FE is an amazing engine, runs smoother and is in better condition than my Xterra i owned previously with half the mileage. Even the XREAS suspension has never been replaced and works as it should! I have replaced timing belt, water pump, spark plugs so far. It has a clunk when going over bumps and potholes so I purchased new ball joints but further research suggests to try replacing the sway bar bushings first so hoping that will fix it. Overall, really happy with the purchase and am looking forward to many more miles.
Ha!
I can't remember if I replied to this post or not...
2004 with 266,000
and I add about 100 miles every weekday!
2006 Sport w/180K
Hey all,
New guy having been a jeep guy in past years looking at a 2006 4runner with 170K and wondered if there are any issues with transmissions and at what mileage point do they crop up? It's and auto, looks to be well taken care of and not much rust on the body, haven't seen frame / floor boards yet. Thanks in advance for any comments.
Regards,
Last Man Standing
Hey all,
Regards,
Last Man Standing
Recently purchased a 2004 V8 Sport with 190k on it and I have loved it so far. Had to replace the timing belt and water pump right off the bat as the previous owner had not. After the test drive it was clear that the shocks were blown... I spent around 900 on the belt and water pump and another 1k on the new Bilstein shocks and labor. Bought the truck for 7500. No rust whatsoever and it had been taken care of fairly well. See if the owner has replaced the timing belt and water pump every 100k miles. If not, I'd get it inspected before you buy. Good luck!
Hey all,
Regards,
Last Man Standing
Welcome! There are a few issues that 4Runners run into, but if those aren't present, it's gonna be a ridiculously solid vehicle (see the post a page or two back where the guy with 800k+ miles is on original engine and trans with basically just regular maintenance).
All of them have seizing brake caliper issues. My recommendation (since it's an easy job) is to get a caliper with a lifetime warranty from an autoparts store and just take it off and replace for free (plus your own labor) if it seizes again.
Early (03-04) V6's had some headgasket issues. Your '06 should be fine if it's a V6.
Only the V8's have a timing belt that needs changing. The V6 engine is basically bulletproof and needs very little besides regular maintenance (oil changes/air filters, the usual).
Definitely look at the frame for rust. They're pretty prone to it and it's hard to stop once it starts.
Some V8's had headers that'd crack, which was covered under warranty for a while. Something to check for, if you're looking at a V8.
As far as I know, those are the common issues to look for. If they're not present, you're good to go to whatever mileage you choose. From what I've seen, most people get rid of their 4th gens because they want to upgrade to a 5th gen, or because they're totaled. Rarely do they get rid of them because of engine/trans problems, or other large work that needs to be done.
Curious what folks are seeing so far as cost of ownership after 150k miles? I know waterpump/timing belt coming towards 180k-200k.
Recently have had a few things require replacing (wheelbearing, radiator) as well as routine services @ $150k. This has put repair bills over $3k in the past few months. At a certain point I'm not keen on continuing to throw 25% of the value in the car for what are small jobs, wondering if it's worth buying a second car and keeping the 4R as a weekend mountain/beach rig to keep the miles off it?
Assuming you're taking it to a shop for the work?? I replaced the full suspension (control arms as bushings were seized, shocks/springs, endlinks, one wheel bearing) and am at maybe $2k in parts over the last year from it, with zero labor cost since I do it myself. And I went with Bilsteins/Old Man Emu springs/adjustable UCAs.
The two years prior (I bought the 4Runner at 159k and it's now at 185k) I spent maybe a total of $100/yr on maintenance things. I think I did an axle ($100 in parts) and a radiator (probably $100 after coolant/parts. Went with a cheap one that's holding up great).
So, for me, there haven't been tons of expensive things that've cropped up. But a $100 DIY axle job turns into a $400-$500 ordeal if you take it to a shop, so I can't really speak to that.
Suspension has been done, but I'm not quite the DIY type nor have space to do so, so I usually take things to the shop.
Gotcha. If you've been going to a dealer, I'd recommend finding an independent shop that'll charge half as much. See what locals recommend.
Other than that, if suspension has been done, it'll just be wear items that fail. Things such as axles, brakes, and wheel bearings. Once you do em, though, they'll be good to go for another 150k at least (or whatever mileage they are when they fail).
Since you're not the DIY type, it might be worth it to get into something newer with a warranty, as most things that fail on these aren't too expensive part-wise. But will get you with labor costs.
May thanks for the good suggestions and insights.
It was a Massachusetts vehicle so hasn't seen much salt
till it came to NYS, so will take advice and let dealer examine first.
Thanks again for the advice and the warm welcome!
sammoore422
kcdehart
I'll just leave this here...
Sent from my moto g(6) play using Tapatalk
