Highest Mileage 4th Gen?
High Mileage
My '06 has 67,000 and still going strong. Haven't had the slightest problem since I drove it off the lot!
04 4.0L with 130,xxx running great except a bank one catalytic converter thats supposidly faulty, more investigation will follow. Same suspension still handles great.
03 v8 sport- 138,000... and counting. I put on only 2000 of that. Scary! Just got it with 136,000.
I hope Toyota won't let me down.
A lot of rust and it needs some things. Brake pads and rotors, e-brake pads, one axle seal, all fluid changes, spark plugs, filters, serpentine belt. Never had the Timing Belt done yet! Scary again. I am getting it done soon and water pump etc. Worst thing is front catalytic converter went out. It is part of the header. It is 1100-1200 dollars installed. My goodness. Glad they both aren't bad. Well not yet.
Best thing is v8 engine and transmission seem good and strong. That is why I bought it. I need at least 200,000 out of this if not 300,000. You never know.
'03 Sport V8, 156+k miles, runs great, no rust, looks good underneath too.
Only thing I had to replace I wouldn't consider maintenance (or normal wear and tear) is the 4WD control module. This was done fairly early, but unfortunately after warranty. My center diff wouldn't lock. Moisture had gotten to it and it had some corrosion on it. It's behind the glove box.
- 4WD control module
- (1) O2 sensor (fairly recent)
- thermostat housing/seal (fairly recent)
- (1) parking light bulb (recent)
- (2) front calipers (recent)
- (4) rotors (originals lasted over 100k)
- (4) wheels (Sport wheels were corroded and peeling, replaced with FJ wheels at ~120k)
- exhaust (muffler was going and also rust, from cat-back, recent)
- shocks (replaced leaking/squeeking XREAS with Bilsteins, recent)
- timing belt (done at 90k per recommended maintenance)
- door locks (did not have to replace, had to take driver door panel off and "play" with switches for a while)
- swaybar bushings (recent)
Highest of the 26 2003s in TrueDelta's Car Reliability Survey is 160k.
Highest for other years:
2004 - 122k
2005 - 97k
2006 - 81k
2007 - 48k
2008 - 33k
Does anyone know if the digital odometer could read upto a million miles? I can't wait 'til i get 999,999 miles and maybe maybe go back to zero. lol
I have a 2005 with 167,000km which is 103,700miles. Problem free except for the rear air suspension.
When I bought mine 3 weeks ago, car had 140k. (2004 TFR V8 4WD).
Then I drove to MN where my gf lives (the new owner of the car), so now car has 142.5K miles and counting.
my dad's 03 V8 has 196,xxx timing belt is being changed for the first time this week. still runs great only problem is the sunroof leaks!
044runner4
