Hitch Install Advice - Broken Tow Hook Bolt
4VetteRunner
I was installing Hidden Hitch 70779 and one of the two bolts for the driver side rear tow hook won't back out. Here is a video:
Video Link
Is there a nut on the inside of the frame that broke that is causing this? Should I just use a dremel to cut off the bolt at this point or is there something else to try to extract it?
I searched for a while for similar threads.
This Thread and this thread seem similar. Are the my best options?
You will be there all day with a dremel. You need a torch or an angle grinder with a cut off wheel. :flamethrwoer2:
DJNutshell
