Hood Scoop functionality
boostedhb
Ok I'm new here, this is my first post been lurking for a while. I just picked up a 2000 SR5 with a hood scoop on it and I was just wondering if it actually does anything, like cool the engine down or bring in cooler air for intake. Because I know the intake system is right behind the headlight. Or is the scoop just like I suspected strictly for looks.
Either way thanks for the help and it seems like everyone here is very knowledgeable when it comes to there runners.
just for looks im sure u can make it so it blows cold air on top of the intake manifold might help a little
Charlee78 said:
Like knight rider ??
OOOooooo I like but no, more like a couple of driving lights for night time boonie crashing. You know I did buy a KITT scanner light for my old audi, mabey it is still lying around?:D
hey guys, i didn't want to start a new thread but i think I found a way to make the hood scoop have some function, especcialy for those of you with the deckplate mod check this out!
38640_lg.jpg~original
this one fits the tacomas but im thinking its the closest thing that can work. maybe maybe not this one. I made a request to volant to look at the 3rd gen 4runner with the hood scoops, so maybe something will come about? here is the link
Volant Cool Air Intakes
you could probably find one of the scoops thats close to fitting the scoop on our runners, and then just run flex hose to the intake
Old thread here, but figured I'd chime in since I'm running a functional hood scoop on my 2001. When I bought it, the previous owner had cut the back of the hood scoop off with a dremel, so it's fully functional now.
Pros: There is a DRAMATIC cooling effect. When you're driving around and you come to a stoplight, you can see the heat pouring out of the hood scoop (like the blurry waves you see coming off hot asphalt in the summer). If you put your hand in front of the scoop you can feel it too. I think this helps to lower the intake air temps a bit and helps with pinging (mine's supercharged).
Cons: All kinds of dust and other crap blows in through the hood scoop and deposits itself on top of the engine. Also, in a rainstorm or a snowstorm you end up with a wet engine. In snow and below freezing temps, this can be a big problem because you can get little pools of water in the low spots and it will freeze in there.
I purchased a part from toyota that effectively blocks the scoop (it is part of the OEM install, and one of the parts that was cut). I just put it back in today to re-block the scoop.
I'm not sure if I'll leave it in or not, but it's easily installed and removed, so I may just keep it in the truck and put it in whenever I want the scoop blocked, and leave it open otherwise.
yeah i know its a pretty old thread and a dead topic but i was looking at some snorkel options Volant offered and saw this. this thing is actually huge and would fit in the grill for a good source of ram air. but it wont fit the the scoop. I thought someone could probably use just the hose and fab up something to connect to the hood scoop?? if they were wanting a functional scoop.
I would think if your running an open intake like the K&N's or even a deckplate mod or volant like mine. your going to get the same thing as far as dust. the water problem would be issue with the scoop being open especially when washing the truck. I spray in that thing like there is no tomorrow haha. Anyway i thought i'd put it out there that it is possible. Got any pics of your setup?
yeah i think im going to cut mine open bc its not like it can hurt. it rains often but only get like 2-3 bad winter storms. that ram air thing is sick though.
even if you made something you can cover it up on the wet days that would be cool? But i even get water in mine with the cover on. i think it drips a little because i get a quick squeak on the belts right after a wash or a really wet day.
yeah i may look more into this Ram air thing when the $$ comes in. I think i can get it to work witht he grill at least
IMO you just get a perpetually dirty motor and a dirty motor will run hotter so you kinda negate any cooling effect to have any real world gains.
I use WaterWetter which actually makes your coolant more effective and I've seen results from this which is better than a dirty engine.
seltzernator
