Hooking Amp Wire to Battery terminal question
piperoo
I ordered my amp kit today, but it doesn't come with the battery terminal...but comes with everything else..wire, fuse, etc, etc
How do I hook the power wire to the battery terminal? Do I only hook it up to the positive terminal with a terminal mount? And then the ground is actually just grounded inside the car on the metal (after scratching the paint off)?
Thanks for the advice!
You've got it right, you should find a suitable ground, close to wherever you are mounting the amp... find the appropriate fitting to clamp/solder on the end of the wire and away you go.
Same for the positive lead to the battery, or you can pick up a new multi-ouput battery terminal, which are handy. Stinger makes a few different options for a half-decent price. I can't remember if the last amp kit I got ever came with that stuff or not?
I am hoping I don't have to put a Cap in the mix as I am not sure where I would put it...but I am going to hardwire a power inverter too, so I might have to down the road.
Also going to put some peel and seal while I have everything out of it....will take some photos of the process.
workingwheelswnc
