Hooking up Accessories
A10MileHusker
Well, this may be a dumb question. But what are the options to hooking up/powering accessories? With my 4 fog lights and CB radio my battery terminal is getting a little packed. I'm sure I'll be adding more accessories in the future and soon wont have any room to connect them! :lmao:
:cheers:
you should get a blue sea block. one wire from the + of the battery and you can ground right by the hood shock bolt for the -.
I made a C shaped bracket and bolted it to the fenderwell. It's a quick and easy way of solving your problem.
Just get yourself about 18" of #4 red and about 12" of #4 black and then 2 terminals and presto...you are ready to rock and problem is solved
WOW!! PERFECT!! Thank you very much!!
i use this one off ebay 350399317088
runs my wire harnesses for headlight low and fog hids, also my hella horns.
use one of these on the + terminal on battery post
ebay 300468706428
that will bolt on the terminal, and have the extra extended bolt for the space u need.
Be VERY careful adding a fuse box directly to the battery. I would suggest putting a fuse as close to the battery as possible. If there is a short (to ground) with the positive lead coming off the battery before the fuse box, you could fry every electrical circuit in the vehicle (and computers). Could TOTAL the vehicle!
Koz
DionicioLives
