Horn?
beerstash
Wanting to replace the horn since it sounds weak as a kitten. Ive looked at replacing them but all I can find in the aftermarket horns are a 3 blade where ours has a quick disconnect. Any ideas? Or do I need to cut the connector off and and convert it to the 3 blade type?
3 blade?? Like, 3 male spades on the horn? I've only ever seen 2 on any aftermarket horns. One is 12v the other is ground.
Just by any aftermarket set of horns, cut the factory plug off the truck and terminate those wires with female spade connectors.
I bought some FIAM Freeway Blasters, with 2 male contacts on them. I simply plugged my stock harness onto the positive contact, and ran a ground.....
