Horrible Headlight Cutoff/Brightness
Well I can confirm that the issue was the bulbs not being fully seated in the sockets. I am not sure how them not being fully seated (they were only out maybe 1MM) caused it but after trimming down the tabs on the H9 bulbs and getting them locked into place the lights now look fantastic. I will be upgrading them to either full HID or LED, but for now they are doing great with the H9’s
If I could offer some advice, be careful with drop in HID's. Lots of cheap Chinese parts out there and with them comes the (very real) risk of degraded performance and failed components due to the increased complexity of the system.
As for drop in LEDs, although there are far better LED options than HID, there are actually an awful lot of poor choices with these. Stay away from the cheap eBay and Amazon crap. If you want truly improved lighting, a pair of $19.99 LED bulbs are just not going to do it.
If you want my 2cents, the H9 swap is about the best bang for the buck you're going to get. It's inexpensive, easy to do and actually results in better lighting. If you go the HID or LED route, you might get improved lighting. Then again, you might not. And you're going to spend a lot more money to find out.
Thanks for the head up! To be honest, after now getting them installed properly and running them a bit, they are so bright and offer a great cutoff, I will probably leave the H9's in there. Even when my brights flip on, it is only a light increase in lighting performance, so as you've said, I always prefer stock over modified equipment/electronics.
D'Angelo
