Hot engine misfire
wallyk50
I just finshed reading about a dozen posts on cylinder misfires, still puzzled.
2000 3.4, 189000 mi. Starts and runs fine when cold, meaning first start in the morning. I can drive about 20 miles and it runs well. If I shut it off and restart, it starts a slight miss which gets worse while driving and after about 10 minutes will turn on the check eng. light. Starting it anytime without waiting for a complete cool down (overnight) it will still miss.
I put the code reader on it pulled P0171, P0300, p0303, p0306. So cyl. 3 & 6 are misfiring. I changed the coil on 3 and replaced all plugs, wires and coil boots. NGK wires, boots and Denso plugs. Also cleaned MAF while it was apart. Fired up and ran like new! Drove around for about 45 minutes, no problems. Ran a lot better than before, looked like the original plugs and wires in it. All plugs were worn badly but #3 was by far the worst. Anyway, next day started up to run errands, drove about 15 miles, stopped, came out and started it up, SOS! Same codes, same everything!
Lean mixture on 3 and 6, cyl misfires on 3 and 6. Am I right on thinking this is ignition related or could it be injectors on those two cyl. failing at the same time?:help::help:
I noticed you mentioned "hot engine misfire" in the title. I had something similar happen to me in my 4R. I got p0171, p0300, and some others. In my case, I would drive my truck for 20 min or more. Its all warmed up and the truck would shut off while driving and start back up on its own (quite violent). Now that's different then your case, but it only happened while the engine was hot. I diagnosed for weeks and changed many parts related to the codes. Found the problem - A Bad Ground on the intake manifold. Something so small was causing these crazy symptoms. Check all your grounds in the engine bay. The ignition wires are grounded on the intake manifold for my 2001 SR5.
FSM Diagnostics of all of those codes being thrown, then removed by new parts or whatever, then returning, all points to the ECM going south.... or what FLORUNNER said......my .02
Where did you get your replacement parts from? Reason I ask is because I put in some new Denso plugs from ebay in and my 4runner would start missing a lot after warm. I believe the plugs I bought were fake Denso's.
Thanks for the feedback. You know I'll be out there checking grounds tomorrow!
About the parts, I was a arts guy for 23 years, retired from NAPA in 2012. I know what I'm buying!
Thanks again guys for replies!
You're most likely getting misfires on those to cylinders due to then running lean I'd check the resistance on injectors cylinder 6 might get hard to reach with out taking the intake off. Resistance should be 13.8 ohms at about 70 degrees. You can also try to listen to them with long screw driver they should click nice and crisp.
wallyk50, did you ever get that issue sorted? I have a '99 3.4 with 330k doing the same thing, just cyl's 1&4 instead of 3&6. I did the exact same thing you did -- replaced the shared coil, plugs and wires... SOS. I'm leaning ignitor, injectors, or ECM, in that order... Thanks!
No, no 0171. Just the 0301, 0304 [misfire Cyl's 1 & 4], and 0300 [multiple misfires detected]. I took it in to a local shop to put on their diagnostic machine. Hopefully they can point me in the right direction.
Local shop had it for over a week. They're stumped and giving up, and I'm picking back up today. I'm going to throw a used but known-working igniter at it and see what happens.
If anyone has a flash of brilliance, I could use the illumination about now... Thx!
NOT the igniter. The search continues.
You might know about the best features of your car, but not about the important car parts. It is important to have detailed knowledge about your buy engine parts so that whenever you meet an uncertainty, you can explain the problem well to the mechanic and get it resolved quickly.
Same problem
Hey guys we're you ever able to solve this problem? I have a 99 with a cylinder One and four misfire. I've replaced plugs coils with no change. My misfire only begins after reaching operational temperature or a hot restart. When the engine is misfiring, if I unplug the injector to cylinder one, there is no change in the problem. So I am wondering if my problem is the injector or is there not electrical going to the injector? Not sure what the value should be to test this. Any thoughts or advice? thanks.
I'll chime in - I went down this road several months ago. I swapped everything and nothing worked but these: Enhance Performance and Reliability with 5VZ-FE Fuel Injectors | MotorWest Performance
Been firing like a champ ever since. It's human nature to hope for the ea$iest solution, but especially with the warm-restart variant misfire, it seems like injectors are the way.
Yeah I just wanted to attempt to narrow this problem down as much as possible before buying new injectors and doing the work to find out it's another problem all together. I will check out the injectors you recommended. Thanks
Same here. I'm not upset that I have new wires, plugs, packs, a clean MAF, an Airaid intake (why not LOL) and decent compression, either. You kind of need to rule those out. While I was researching the issue it seemed like the vast majority of the warm-restart misfire folks ended up replacing the injectors. I could run fine all day, but if I made a brief stop the engine would stumble badly upon restart. I'd have to sit in the lot for 20 mins with the hood up until I could cool enough to drive normally again. I spent a month+ like that and avoided multi-stop trips whenever possible.
My "hot" misfire ended up being the wires, ordered the NGK wire set from Rock Auto. I previously swapped the spark plugs around to rule those out (still had the flashing MIL and same code for the same cylinder), but I did install new ones while changing the wires.
It sure seems like the misfire on hot start has a large number of causes. I've put in coils plugs and wires so I'm guessing now is injectors. I am going to try to get the service manual and see if I can test any electrical parts prior to swapping them out. Going to order the Motor west injectors. Cant beat lifetime warranty!
tuṣṭāva
